Results 1 to 6 of 6
Thread: Starter VS Battery
    V6 VR Acclaim
    Jun 2010
    Default Starter VS Battery
    Heh, ironic story. I pulled over last night to help this guy who had broken down 'round the corner from my place. I turned my car off, etc. It was running perfectly fine before I pulled over, but once all was said and done, my car refuses to start. Everything still works, stereo, high beam, etc but when I turn the key, I just get that synonymous "click".
    Starter? If it makes it any easier, my car was being a bitch to start for the last couple months and I figured it was on it's way out.. But couldn't really afford to replace it.
    OH.. That's a "vs" (versus) not a "VS" as in commodore.. I suppose I should have left it in lower case ;P
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It could be the starter motor or the battery. That click often happens when there is not enough power in the battery to turn the starter motor. I suggest cleaning the battery terminals and make sure the clamps are tight and see how that goes. If you have a multimeter, check the voltage of the battery and also check what the reading is when you attempt to start the engine and post results.
    MY RIDE
    '97 VS Commodore Wagon
    Jul 2011
    Sometimes this happens to my car, I usually disconnect and reconnect the negative then it starts right away.
    304runner's Avatar
    304runner is online now ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Yeah sounds like a dodgy battery connection or battery itself.
    But if the battery is fully charged the it could be your starter.... Give it a tap with a hammer or something and see it that makes a difference....
    V6 VR Acclaim
    Jun 2010
    Turns out the main earth line was cut/severed somehow. It's all fixed now . I am guessing it has been like this for awhile since the slow increase of time it takes to start my car.
    Thanks for your input guys ! At least I didn't end up having to spend shit loads on new parts :P
    VY SS
    Jun 2006
    Albany
    if its one loud click then nothing it sounds like the contacts in the solenoid are burnt out or you are getting volt drop to the start wire to the solenoid, do all the above things first like cleaning all battery terminals. also try starting with your lights on, if the lights dim there could be a fault in the starter but if they dont dim its prob just the solenoid.
  1. battery or starter??
    By mynameisearl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-10-2010, 03:56 PM
  2. VS Battery, Starter or Something else?
    By hsv91ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2010, 10:00 PM
  3. Battery or starter
    By Rumbl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2009, 09:03 PM
  4. Starter motor or Battery
    By Legs in forum General
    Last Post: 27-06-2009, 07:29 PM
  5. Replies: 1
    Last Post: 17-01-2005, 05:39 PM
