Results 1 to 11 of 11
Thread: weird grinding/knocking in the left front wheel
    VS Executive s2
    Feb 2011
    Albury
    Default weird grinding/knocking in the left front wheel
    hey guys,
    I was driving along the other day, turned left around a corner at about 40-50
    (not fast because it was like a vear off from a 70 road) anyway, i heard a bit of
    a grinding noise in the left front wheel, but it only does it at say 20km/h around
    a corner, it doesnt do it if i stop and turn, say at traffic lights, or when i go slower
    than 20.
    Lately this noise has turned into a bit of a rattle, which sounds like the spring rattling
    a bit, seems strange, but on the odd occasion this grinding occurs again.
    I took dad and my brother in law in the car for them to listen and they said its only because
    i lowered the car and thats just what happens, also because my wheel has a slight buckle
    they are only temporary wheels because i damaged 2.
    Does anyone have any knowledge on this or any theory as what it could be
    i dont want to go to a mechanic and be charged say $120 too put it on a hoist, look at it
    and tell me its f$@$ed, if any of the jc guys/gals have an idea :P
    (you guys seem smarter anyway )
    Thanks in advance,
    Corey.
    Quote Originally Posted by Mumboman View Post
    I was lucky I got a lesbian.... She came out straight after it and I got my P's.... Happy endings for all
    commodore
    Aug 2009
    australia
    could be wheel bearings ,id be jacking it up if i was you to check everything else is tight and nothing broken under there if i was you..
    commodore
    Aug 2009
    australia
    another thing id check is the swaybar link pin they have a habit of punching straight through the washer which the bush sits on ,at least my vr ones did twice..
    VS Executive s2
    Feb 2011
    Albury
    cheers mate, will jack her up tomorrow and have a look and a bit of a tighten on
    everything around that area, as well as check for anything broken, although it sounds
    ALOT like its the spring rattling just a little bit, how much damage can be caused
    if i left it for a month or so?? everyone i have asked that knows anything about cars told me
    that it wont damage anything and its just a noise that will piss me off. Being a P-plater, i have
    my music turned up so if its only a noise that will annoy me i will leave it for a month till i acquire
    funds to take it to the mechanic, after checking said things
    commodore
    Aug 2009
    australia
    in that case id be checking the strut top nuts they might be loose also if you cut your springs to lower it they can easily dislodge out of their proper positions so check your spring is seated correctly.
    VS Executive s2
    Feb 2011
    Albury
    well ended up at school longer then expected, so no time to look at her D: hahahaha i like
    how when i say p plater you think cut springs :P nah they are legit pedders sports rider
    or something ones ahaha but i sill check the spring bump stop thing and tighten the nuts up
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Quote Originally Posted by vsowner94 View Post
    Tell me you are joking, right?
    Stop being a cheap prick and take it to a mechanic. If you cant afford to maintain your car, you cant afford to own one
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    VS Executive s2
    Feb 2011
    Albury
    yep cheap prick, because im currently doing my hsc certificate and cant work many hours
    so because of this your gunna be an absolute prick and try all that bs about "cant afford
    to maintain it cant afford to own it" well geeet f#%ed considering its just had new steering rack
    and ps pump, new muffler etc. but yano i cant afford to do one simple thing at the moment
    due to a school matter and suddenly i cant afford to own it. people like YOU are the reason we
    young people drive around in unroadworthy and dangerous cars, because we ask for some help and
    you say this shit.
    On a happy note, thanks sooo much bogan_vk, it did end up being 1 nut loose in the top of the strut,
    tightened it up and she is back to being quiet
    Jan 2008
    you say this shit.
    People like me?
    Sure.
    I Maintain my cars.
    My cars are inspected every 6 months by a qualified mechanic, under this great system we call 'Warrant of Fitness'.
    You said, in your first post, that you didnt want to take it to a mechanic because he might tell you it was unsafe.
    Whos the one with the problem now mate?
    Jan 2008
    you say this shit.
    People like me?
    Sure.
    I Maintain my cars.
    VS Executive s2
    Feb 2011
    Albury
    i didnt say him to say unsafe? i meant
    him to inspect it, charge me $120 when it
    could have only been a $10 job to fix. turns out
    it was a only a few bolts needing tightening, but
    im sure a mechanic would have got the inspection
    fee thing, then found a few more things that needed
    to be "fixed" sorry for that last outburst though, having
    a bad day, didnt mean for it like that, thanks for your input though
  1. grinding noise from front left and metal shards found on inside of wheels?
    By hsv91ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-11-2010, 01:11 PM
  2. Weird rattle on front left corner
    By soop in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-10-2010, 03:25 PM
  3. abs fault and weird grinding from the front of car
    By [Linkin Park] in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-11-2008, 10:18 PM
  4. grinding noise under front left
    By DannyboyDS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2008, 10:02 PM
  5. Left Wheel Knocking noise when turning at low speed
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-01-2008, 09:37 AM
