Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By wraith
Thread: vp engine to Vr
    vx executive s2, vr executive bt1
    Jul 2011
    lansdowne nsw
    Default vp engine to Vr
    My Vr bt1 engine has developed a problem and my father has a engine out of a vp series 2. Just wondering ifig would bolt straight up?
    VS Executive s2
    Feb 2011
    Albury
    sadly even if it did, its illegal not aloud to go backwards with engines, only forward
    Quote Originally Posted by Mumboman View Post
    I was lucky I got a lesbian.... She came out straight after it and I got my P's.... Happy endings for all
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Again with this older motor BS. The 5 litres are all the same up to the VS I believe. VT had other things. If it's a 5 litre you should be fine. Same emissions gear etc.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    v6 or v8?
    v8: drop in and enjoy......
    v6: change timing cover to the vr one (because they have the cam angle sensor) then drop in and enjoy
    VS Executive s2
    Feb 2011
    Albury
    well i was assuming it was a v6 sorry, they are right v8
    is straight swap v6 cant legally go backwards, i had
    the same problem with my vs, wanted to put in a vr
    engine, only to find out it was illegal
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    My vr has had a vp engine for as long as I have had it....apart from the cam sensor they are exactly the same ..and the dipstick location is different.....surely if you advise the wankers at the transport dept of the change in engine number all would be good..
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. missing engine cover bolts 5 litre engine
    By justice4all3000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2011, 06:17 PM
  2. vx coughing and spluttering after v6 engine swap with wrong engine
    By bogan_vk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 08:11 PM
  3. VS Ute Engine just fitted but engine light coming on and not going into overdrive
    By MX_Leigh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2010, 04:53 PM
  4. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
