Results 1 to 11 of 11
Thread: vs ute code 85
    vs commodore ute
    Jan 2010
    nsw
    Default vs ute code 85
    hey guys was on me way home the sarvo and pulled out onto the highway and ute wouldnt go into fourht gear
    got home checked the error codes and come up with code 85 i cant find anywhere what code 85 is
    also car would go into fourth with the foot taken off the accelerator
    any help would be appreciated thankyou
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    error code 85
    Transmission slipping difference between engine rpm and transmission output rpm
    note this error does not illuminate the powertrain check light
    MY RIDE
    vs commodore ute
    Jan 2010
    nsw
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Things I would do are: disconnect battery for 30 mins to reset ECU....check trans fluid level.....check fluid colour and smell - if brown and burnt smelling replace. Check the trans fuse (not sure which one in a V8).
    Hopefully it's just a solenoid or something simple.
    vs commodore ute
    Jan 2010
    nsw
    vs commodore ute
    Jan 2010
    nsw
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sometimes..., resetting the ECU by disconnecting the battery can fix strange electronic problems. Your transmission is controlled by the ECU. This cost nothing, can do no damage and takes little time to do.
    It's a bit like when your PC locks up or doersn't load up properly...you turn it off, wait a few mins and reboot - of course your ECU isn't a PC but they are similar. But try it anyway, and also the other suggestions especially the trans oil colour.
    Good Luck.
    vs commodore ute
    Jan 2010
    nsw
    Quote Originally Posted by hako View Post
    Good Luck.
    hey mate disconnected the battery to reset the ecu like you said and it fixed the proble thanks heaps for the adice
    just wondering what would have caused it in the first and could it happen again
    also had the transmission fluid changed and new filter put in about 3000 kms ago
    thanks again
    vs commodore ute
    Jan 2010
    nsw
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by vs-v8-ute View Post
    thanks again
    There is no guarantee the code will not come back unfortunately. Last time I had a trans related code it went away after disconnecting the battery, then re-appeared about a week later - that was a code 82 which is one of the solenoids in the trans. A few weeks more and it was on all the time as well as Limp Home Mode. Yours could be similar and from your description of the fault it could be as simple as the solenoid that controls the TQ lockup.
    What I'd do is drive it normally and see if it comes back - if it doesn't log the code in the next 6 weeks or so then I'd say it was something very simple like a bit of dirt in the valve body etc, but if the code comes back in the next few days then you will need to do some more investigation. I'd also check the trans oil colour just to give you an indication of the general condition of the trans - it should be pink/red and smell oily. IF brown it suggests the trans has been slipping and/or the trans is nearing the end of it's life. However, to contradict the last sentence, when your trans gave the code 85 it would have been slipping quite a bit, and this heats/cooks the oil....so really diagnosing problems is pretty near impossible.
    But check the oil, change it again if brown and keep fingers crossed. If you trust the person who did the last trans service then ask them for advice as well. Good Luck.
    vs commodore ute
    Jan 2010
    nsw
    Hey hako thanks for your reply I checked the trans fluid smells like trans fluid should and it is a red/pink Colour hopefully it wont come back will have a chat to the bloke who did the service and see what he says
    Thanks for your help mate
  1. error code 12, 3 times then code 76
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2010, 06:36 PM
  2. LSD Code
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2009, 04:01 PM
  3. Code 76
    By inais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2009, 06:02 PM
  4. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
