Results 1 to 7 of 7
Thread: vibration after replacing engine mounts..?
    vs calais
    Dec 2008
    Default vibration after replacing engine mounts..?
    Hi everyone,
    I just replaced my engine mounts on a v6 vs calais. Replaced both the driver and passenger side mounts with genuine Holden ones.
    Now the car has a slight vibration in first gear just before it changes to second.
    Does anyone have any ideas as to why this is? the vibration wasn't there with the old mounts.
    Cheers in advance
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by James39 View Post
    Did you do the trans mount?
    yeah consider this, lets say the engine mounts were screwed - motor was sitting down a bit lower than it should. trans mount is the same age, similar story.
    engine mounts replaced, trans mount stays old = weird angle? could be causing your vibration.
    changing the trans mount if you haven't done so.
    vs calais
    Dec 2008
    I didn't change the trans mount yet. It might be this like you say.
    Before I do go ahead and change it, does anyone else have any ideas???
    Do you think I could have stuffed something in the box, or uni's while jacking up the motor?? I didn't go too far.. just enough to pull the mounts out
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Yes, if the mount is lose or worn, it will cause the problem you have.
    Plus you will notice it even more going up a steep hill.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Jacking the motor up won't stuff any drive shaft components. +1 for trans mount.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Try resettling the mounts and the exhaust , loose off the engine mounts and trans mount and exhaust pipes , start the engine with your foot on the brake and the hand brake applied shift the auto from park to rev to drive afew times then switch off the engine and re tighten the mounts and exhaust. recommend doing this on a hoist or on the ground where the wheels are in contact with the ground , not while supported by jack stands as a chance of vehicle falling is high if not done correctly raise and lower the vehicle to loosen and tighten the mounts and exhaust
  1. vt 3.8 droning vibration after replacing engine mounts
    By som in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2011, 10:06 PM
  2. Replacing Engine Mounts (anyone in Adelaide?)
    By mayes in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-05-2010, 02:19 PM
  3. Replacing front engine mounts on 6cylinder VT
    By javjup in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2009, 08:30 PM
  4. Replacing Engine Mounts
    By truni in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2008, 08:47 AM
  5. replacing engine mounts on a VT
    By Stue in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-12-2006, 09:44 PM
