Results 1 to 7 of 7
Thread: DBL ROW timing chain and balance gears
    VS S-Pack SII
    May 2008
    Default DBL ROW timing chain and balance gears
    I'm curious, ive been searching everywhere on the net for a good photo, posts etc... and come up empty handed...
    Exactly what stops you from fitting the double row timing chain and keeping the balance gears...?
    Duh... space i know... but what if the balance gears where machined/lathed a bit thinner?
    My reasoning... all this talk about vibration at 1700RPM... at 100km/hr... the engine revs at... you guessed it... 1700RPM.
    and considering my driving is 90% on the freeway at 100... it is kind of an issue for me...
    and what about making up a spacer to go between the timing cover and block... say a 3mm spacer and then use 2 gaskets? (cover, gasket, spacer, gasket, block)
    the issue i see there, is how much clearance is there between the harmonic balancer and the timing cover? (dont want the harmonic balancer rubbing)
    so yeah...
    Thoughts please....?
    VS
    Jul 2010
    Sunshine Coast, Queensland
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Everyone always talks about the dreaded 1700rpm vibrations but to be completely honest, I have no vibrations at that rpm and I have a double row with the balance shaft removed....
    I'm pretty sure there is no way at all to keep the balance shaft and go double row.... (well from everything I have read)
    Best part about putting in a double row, is no more tensioner and stopping the annoying balance shaft bearing noise that happens alot :P
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I have a double row and haven't got any vibrations.
    Ronald Reagan (1986)
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Nope! Not possible at all to retain the balance shaft. There just isn't the room. If you do a search i've posted some pics of this not all that long ago including blocking the rear oil feed if you remove the shaft all together. In my experience any vibration that occurs is more like 1400 or so, but is so very minimal i think you'd get worse vibes from a stuffed engine mount. As for spacing the timing cover out, this won't work. The crank and cam gear both go back to a machined shoulder and naturally just spacing out the timing cover doesn't bring them out with it. Spacing the amount you've suggested would also misalign the threads for the sump bolts into the bottom of the timing cover.
    Are you looking to fit an aftermarket cam?
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    VS S-Pack SII
    May 2008
    Quote Originally Posted by cander24 View Post
    Thankyou for actually adressing my question instead of just giving me the normal "why would you do that?" reply.
    Good points about the lower sump bolts and recessed gear.
    I can see where you are going with the cam question... and if i was to use an aftermarket cam, then the "lumpy" idle would mask the vibrations, if any, that i may feel at 1400rpm.
    VS S Pack
    Sep 2009
    if you really want to keep the balance shaft but still want to go with a better timing chain, you could use the crow cams CS6VS as it is a singe row timing chain so you can keep the balance shaft but it gets rid of the failure prone tensioner
    really the double row chain is only needed if you go a big cam that puts more load on things
  1. Replies: 10
    Last Post: 23-04-2012, 11:59 AM
  2. timing chain
    By clazzza commy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-08-2011, 08:16 PM
  3. Timing chain - straight cut gears possible on a v6?
    By sp001in in forum V6 Development And Modification
    Last Post: 15-11-2010, 01:46 AM
  4. timing chain
    By veeteecommo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2008, 10:48 AM
  5. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
