Results 1 to 7 of 7
Thread: VS bcm - key head
    VS Benz
    Jan 2010
    Default VS bcm - key head
    Im using a vs engine/ecu in a conversion and what to retain the bcm rather than bypass as per typical.
    At what point does the bcm read the key head? I assume its only at crank...
    can anyone confirm or deny
    cheeRS
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    yes on key turn it contacts with the key ring around the lock to disable the alarm/immobilizer so it will start, same as with lock/unlock buttons
    VS Benz
    Jan 2010
    So I bascially only need contact while trying to start the engine. once running etc the keyhead contact can be removed.
    just confused then as why the contact path on the barrel swings for all positions of the key head? rather than just a start connection
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    VS Benz
    Jan 2010
    Ive put vs eng/box and complete commodore wiring loom into a mercedes. I want to retain the security features of the key/bcm as Im also using the key button/central locking function... but will have 2 keys as the merc ignition barrel cant be modded to get the reading strip mounted, nor the keys mashed together. Im trying to work out what i need to work, if i need to create "fake" second barrel for the vs key, or just a touch pad for the key head when trying to start it.
    If the imob is cut @ 'on' position then it sort of makes the decision pretty clear.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    id wire the ring up somewhere with a magnet behind it near the barrel, the keyhead nipple should stick to it then.
  1. Head unit running off head lights?
    By billyjim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2010, 04:44 PM
  2. head lights cut out head unit.
    By Silver_VS_II in forum Electrical Wiring / Questions
    Last Post: 03-05-2010, 11:39 AM
  3. Ecotec head gasket replacement and head linish
    By VOSBMX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2010, 10:08 AM
  4. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  5. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
