Results 1 to 9 of 9
Thread: Snapped bolt in thermostat housing. Please help. Pic.....
    1999 vs ute series 3
    Oct 2009
    Default Snapped bolt in thermostat housing. Please help. Pic.....
    Ok when doing a coolant flush I took my thermostat housing off and one of the bolts snapped when undoing it. I e tried easy out and they kept snapping and pretty much the thread is completey ruined. What know? Looks like it's apart of the intake manifold? Is there a way I can get around this? I have put a screw in there but it is leaking and loosing coolant.
    Quote Originally Posted by Jonnii View Post
    yeah well it is a ute its not supposed to be about comfort
    http://forums.justcommodores.com.au/...rst-car-d.html <<< My 5sp vs ute
    Oct 2009
    Just realized you can't upload pics on iphones
    VX acclaim S2
    Oct 2009
    U can with tapa talk app, and I had the same thing on my mates vr Buick, ended up drilling it out re tapping it and new bolt, all sweet
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Yeah your only real option is to bore it out and then retapp it to a larger bolt size basically.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    VS Berlina/ KJ Verada
    Sep 2006
    Depending how close you are to a wrecker you could save the rooting around of retapping and get a second hand inlet manifold, that way you can can change the gaskets too which prob wouldn't hurt and have peice of mind that all is ok...
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    Oct 2009
    Yeh I was thinking about buying a new manifold. How hard are these tap and die sets to use?
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Pretty easy. Or if you dont have a tap, you may be able to get away with helicoils. Need someone else to either confirm or deny this claim tho.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Quote Originally Posted by seq4x4 View Post
    You will need to drill and tap the hole first before using a helicoil , best to drill the broken bolt out and remove the broken stud completely , if you arnt confident in doing this job then give the thread doctor a call and he will come out and do the job for you for a price
    VR Statesman 5.0L
    Sep 2011
    if you wish to repair by helicoil, you first need the kit as the thread insert usually has an odd type of thread and therefore a purpose built tap.
    but if you follow all the instructions that are on the box you will end up with your original thread size in the hole and generally a stronger thread than what you started with.
  1. Plastic Seat Housing - Snapped!
    By mattsv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-08-2011, 08:43 PM
  2. Thermostat housing bolt thread sizes
    By thephilth in forum V8 Development and Modification
    Last Post: 26-11-2010, 09:46 PM
  3. Snapped thermostat housing bolt
    By vs_wagon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2010, 11:35 AM
  4. vr commodore manual-snapped the housing around the tailshaft connector to gearbox
    By ital355stroker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2008, 09:11 PM
  5. HELLP Thermostat housing snapped.. Where can i get a new one and how much ?
    By JustVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2008, 06:53 AM
