Results 1 to 8 of 8
Thread: vs brake shudder
    vs ecotec
    Sep 2011
    Albany
    Default vs brake shudder
    i have a problem when i brake my steering wheel vibrates n shakes
    does anyone know what this is
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    warped front rotors.
    They will need to be skimmed or replaced if they are too thin.
    muttley383
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    X2 warped rotors or grease/dirt on them in both situations you need to have them machined.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It could also be worn tierod end or rack ends. Warped rotors will also cause the brake pedal to pulsate as the warped rotor forces brake fluid back to the master cylinder.
    vs commodore
    Oct 2009
    Tamworth NSW
    Also worn front wheel bearings/front hub bearings can cause shuddering under braking, even if the brake discs are just slightly warped, these days brand new brake discs are so cheap to buy, that its just not worth getting the old brake discs skimmed/machined, and machined discs are never as good as brand new ones anyway. Check out ebay for the cheapest prices on new discs. Also these front wheel bearings cant be replaced and the whole front hub has to be replaced as a complete unit. Theres different hubs for ABS/non ABS equipped vehicles, and the ABS hubs are handed left and right, and theres different hubs for IRS/non IRS ABS equipped vehicles.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Warped front rotors from me too. New rotors and pads will fix your problem.
    I do slotted rotors and pads for $230 shipped to Albany. Or I do a custom curve slot with dimples and hi performance pads for $280 shipped.
    Visit my Facebook page
    vs ecotec
    Sep 2011
    Albany
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Appreciate the responce.
    Always more helpful knowing the issue is fixed.
  1. VR Brake Shudder - Help!
    By ultra_pikey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2009, 08:50 PM
  2. Brake Shudder on VX
    By garywg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-03-2008, 04:41 PM
  3. Brake shudder???
    By PaulW in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 11:08 PM
  4. Brake Shudder
    By kiwiscole in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-09-2005, 11:28 AM
  5. brake shudder
    By Rodger57 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2005, 07:49 PM
