Results 1 to 7 of 7
Thread: BCM Interesting..ness.
    93 VR Berlina
    Jan 2010
    Default BCM Interesting..ness.
    Hey all,
    When i bought my car one of its known faults was no cruise control and no power mirrors, i put that down to either fuses, or stalks. So i didn't bother, but most recently, central locking has stopped working, via the key and manually locking, and the power windows has stopped, so basically cruise, mirrors, windows, locks. Everything that goes through the BCM, so i went in search, ripped out the one from under the drivers side dash and went to Eastcomm, they had a perfect match but it didnt fix anything, then he (eastcomm man) said he THOUGHT early VRs had another BCM, so i found it under the passenger side dash, ripped it out and he didnt have a match, so im on the look out.
    Am i searching for the correct component? I can't think of anything else that would make central locking and power windows fault, especially with the other two, all fuses relays etc are fine, so i gotta assume its the 2nd, smaller BCM on the passener side?
    Also, its for a Vr V6 Berlina, 92043 522 TDM is the model number on the BCM im now searching for if anyone has one or finds one, thanks guys
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    The one on the passanger side is the ECU(PCM) the drivers side is the BCM The one on the passanger side has SFA to do with your power windows etc
    vs commodore
    Oct 2009
    Tamworth NSW
    The Tech 1 scantool shows that some of the earlier VR models with MID or HIGH BCM's, have a seperate TDM (Theft Deterrent Module) fitted, as well as the normal MID/HIGH series BCM. The mid/high series BCM's took on the job of looking after the anti-theft stuff in the late VR and later models.
    93 VR Berlina
    Jan 2010
    Yeah we have a TECH1 at work, and yeah i have (apparently) a HIGH series BCM and a 522 series TDM, theft deterrment module, apparently.
    vs commodore
    Oct 2009
    Tamworth NSW
    The tech 1 will show up what series TDM and BCM you have. Ive no idea though if the TDM has an ID sticker like the BCM's have. Ive just come across them a few times when Ive had my tech 1 plugged into either a VR acclaim or berlina with mid level BCM. I havent had the chance to plug it into a VR calais yet, but I guess they would be the same also. I think the calais etc with the high series BCM has a seperate ALDL connector under the dash connected to the steering column, the plug is coloured green.
    93 VR Berlina
    Jan 2010
    If either BCM isnt work, will my head unit not work? I ve wired it all up fine according to holden--> pioneer wiring diagrams and it doesnt work =\
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by Brett_jjj View Post
    And they have the key over ride that turns it off completely?
  1. Please don't hate my n00b-ness
    By Scotto88 in forum VE Holden Commodore (2006 - ?)
    Last Post: 14-07-2011, 09:48 PM
  2. Interesting pic what is???
    By yentzelburger in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-07-2011, 09:01 AM
  3. interesting VL info
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-10-2006, 02:44 PM
  4. Bit of interesting reading
    By Outlaw Torn in forum The Pub
    Last Post: 15-07-2006, 08:20 AM
  5. Interesting...
    By rattattack1313 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2005, 10:34 PM
