Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By PanthaVS
Thread: Can i clean a shift solenoid?
    vs commodore
    Aug 2011
    Default Can i clean a shift solenoid?
    Is there anyway of cleaning a 1/2 shift solenoid that will fix it? I am getting an error of "Code 82 - 1 - 2 Shift Control Solenoid Fault - Auto Transmission Only" and my VS is crunching a little from park to drive and first to second. Just wondering if there is a way to fix this problem for free or if i should just wait until i can afford new solenoids.
    VS S-Pack SII
    May 2008
    have you looked at what they're worth? I think they're like $20-30 for both A and B shift solenoids...
    And considering you have to spend at least $120 in fluid and filters just to get to them... you might as well replace them. considering how easy they are to get to.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've never heard of anyone going to the bother of cleaning a solenoid in an attempt to fix it - usually they go either open or short circuit which you cannot fix. Added to this, you also need a new gasket and 4 litres of DX3 just to reach the solenoid. Finally solenoids only need replacing when they fail and there is little to be gained by replacing all 4 at the same time. They are pretty cheap on Ebay.
    You could try disconnecting the electrical connection to the trans and cleaning it although that is a long shot. Reset the ECU as well by disconnecting battery cable for a few minutes.
    vs commodore
    Aug 2011
    thanks for the replies guys. I am trying to sell the car atm and was hoping i could of fixed the problem for free, if its going to cost $120 in filters and fluid and $30 for the solenoid i wont even worry about it.
    VS S-Pack SII
    May 2008
    sell the car like that and you won't get squat for it... I'd spend the money to make the money if i were you... otherwise, as soon as someone test drives your car... they will feel the crunching... and assume a $2000 transmission replacement is required.... that equals no sale!
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    lol at fixing it so its fine for when u sell it but will break as soon as its sold.. not cool dude
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    VS S-Pack SII
    May 2008
    Ha! it's only a shift solenoid... not banana skins in the diff! :P
    Pain to all those who do dodgy tricks to sell a car!
    vs commodore
    Aug 2011
    i get your point but im only asking for $1500 so i really don't feel like putting a few hundred into it to not get anymore back.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by asht12341234 View Post
    If you are going to do it yourself the fluid and filter will be around $60. Which is just to drop the old fluid in the pan and changing the filter. A proper flush will cost a lot more....
    vs commodore
    Aug 2011
    Quote Originally Posted by [jonnoo] View Post
    That is not at all what i asked.... i asked if there was a way to FIX it for free, not fix it for 10 minutes while someone test drives it.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    What I'd do is disconnect the battery for 30 secs to erase the code and then reconnect. The code will not come back till the solenoid fails again as usually they are intermittent at first. This way you may get lucky and it will not show up while you are trying to sell the car. If you want to play it straight just mention to the buyer that it did show a fault code but it went away. For $1500 I'd expect a few surprises.
  1. Vs shift solenoid
    By Mr_VS_Berlina in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2010, 10:48 AM
  2. 2/3 shift solenoid
    By MUNTED6 in forum Sticks's EFI parts
    Last Post: 17-09-2010, 01:02 PM
  3. Code 81: 2-3 Shift Solenoid
    By Barto76 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2010, 01:10 AM
  4. 3-2 shift control solenoid
    By mish22 in forum General
    Last Post: 22-01-2007, 05:35 PM
  5. 3-2 Shift Solenoid
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2005, 09:23 PM
