Results 1 to 7 of 7
Thread: Vr ss splutters and stalls
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    Default Vr ss splutters and stalls
    Hi,
    got a problem with my vr ss 5.0L.
    so far it has done it twice,today and once about a year ago,both days were pretty warmish days probably around 30 degrees.
    Took off from the lights like normal,got up the road and,
    :Tacho bounced between 900-1200 rpm.
    :engine start to splutter and go on
    :as i pulled over and came to a stop it stalled
    Tried restarting and it fired but stalled straight away again.
    If it does idle,its poorly and if you put it in drive or foot down to rev it,it will stall.
    After letting it sit for at least 15-20 minutes it will fire,some times no problems like today (car sat for about an hour before trying to start again),other times will only go for about 5 minutes and stall again.
    Ignition module was replaced a year ago thinking this was the problem and hadnt done it till today probably due to not being driven much and also winter/cooler months.
    Any ideas? dont want to be stuck on the side of the road with a 6 month and 3 year old on a hot day again...
    vr commodore executitve, manual vn executive
    Mar 2011
    sydney
    how old is the fuel?? and also check the fuel pumps, happened to my vr a few weeks back
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    Mar 2011
    sydney
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Could be the sensor in the dissy. Mine did similar things, i had a sapre dissy so swapped them over set the timing and off we go.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    +1 for Dizzy and/or bad fuel/pump
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
  1. vs v6 ute idling bad and coughs splutters ect when trying to rev
    By favsute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-07-2011, 05:49 AM
  2. 1995 VS commodore girks and splutters under low accerleration but not high acc..
    By dubknight in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2010, 05:45 PM
  3. VS ute randomly splutters and dies
    By beck.jmg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2010, 11:48 PM
  4. Just splutters like a rev limiter
    By newtownbob in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-04-2008, 08:03 AM
  5. VP 5.0l coughs and splutters
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2005, 09:41 AM
