Results 1 to 2 of 2
Thread: problems vs v8 ute
    vs ute
    Sep 2011
    Buninyong
    Default problems vs v8 ute
    tonight driving home had a small flat spot, got worse then started to backfire then would cut out then just go again, would drive fine after that about 5 kms then do it all again, about 2 weeks ago changed ignition moduile because ute just stoped one day just not been right
    any tips guys??
    VR BT1 V8
    Jan 2009
    Geelong vic
    You should check your distributor cap for cracks and wear. It sounds like you have a worn cap.
  1. Signal Problems Aand LPG Problems
    By reyyan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 08:33 AM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. Id like to know common problems with air con in vt so i can diagnose my problems
    By dope505069 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2010, 03:21 PM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. VK Oil Problems
    By Donna in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-02-2006, 05:29 AM
