Results 1 to 9 of 9
Thread: How to remove lower intake manifold?
    1999 vs ute series 3
    Oct 2009
    Default How to remove lower intake manifold?
    I've tried searching the forums but can't find an answer. I'm trying to remove the lower inlet manifold. I've remove plenum injectors all the sensors and what not and the bolts holding it down. It's moving around but the looks like something under the thermo housing that is holding it in?? I need to replace the whole lower inlet. Also what gaskets or seals am I looking to replace? Cheers guys
    Quote Originally Posted by Jonnii View Post
    yeah well it is a ute its not supposed to be about comfort
    http://forums.justcommodores.com.au/...rst-car-d.html <<< My 5sp vs ute
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Near the front left there is a heater pipe that goes into the side of the inlet manifold that needs to be pulled out enough so you can lift out the inlet manifold.
    But I got the inlet manifold out without doing that that lol but to make things easy there is a wire that is bolted on the front top left which you can remove... This is where you can remove the heater pipe by undoing these bolts... there is two heater pipes which will need new O-rings....
    In the picture the red arrow is the pipe that needs to pulled out a bit and the red circles are the bolts that you need to remove....
    VS Acclaim
    Jul 2011
    NSW
    Yeah when I have done it before I just pull out the inlet manifold sideways slightly, comes out easily. Although it was an absolute bitch to put back on once I fitted a new o-ring (must have been slightly larger)
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by Robb View Post
    It is easy when you slide the heater pipe out of the way when you put the inlet manifold back on.
    Oct 2009
    Ok thanks guys will give it a shot tonight. Are there gaskets under the manifold?
    VS UTE, HT MONARO REBUILD
    Dec 2010
    Quote Originally Posted by MADDNE33 View Post
    sure are, you will need the two inlet gaskets (one for each head) and a front and back seal (sits in the middle of the valley), these days im pretty sure you can get them in a kit for around 60 bucks or from holden for $90. hope all goes well. i am also planning on changing the manifold gaskets in a few weeks. was gonna do it today but insufficient funds mean i have to save up a bit of cash.
    VS Acclaim
    Jul 2011
    NSW
    You can get the inlet manifold gaskets from mace that supposedly will never need replacing again. I used that one, I think it was slightly over $100.
    Oct 2009
    Haha well I don't plan to keep this motor in for much longer so might just stick with the repco ones and does the package include the o rings?
    Oct 2009
    Ok tried again and that pipe just would not move so I ended up having to pull the tensioner pulley and alternator off. Does this pipe slide out easy or does it need to be pulled out? Also there was a large build up off brown muck in the water jackets on the heads. Docent look to nice is this normal?
    Cheers for the help guys
  1. [VZ] How to remove intake manifold (175kw motor)
    By vzberlinav6 in forum Holden Commodore How-To's
    Last Post: 31-03-2011, 11:07 PM
  2. VM front lower grill - how to remove?
    By NORTI in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-01-2011, 12:21 PM
  3. How do I remove my lower control arm? or pivot bush.
    By VT_sleeper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2009, 06:17 PM
  4. porting lower vt intake
    By 85SS/85GN in forum V6 Development And Modification
    Last Post: 09-11-2009, 04:52 PM
  5. Need info on lower intake manifold
    By Zooomer in forum V6 Development And Modification
    Last Post: 27-04-2005, 03:25 PM
