Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Like Tree1Likes
Thread: vr v6 bad fuel economy
    vr commodore executitve, manual vn executive
    Mar 2011
    sydney
    Question vr v6 bad fuel economy
    ok guys, i have recently had a sports catback exhaust put on 2 1/2 inch, and ever since then my fuel economy has gone to crap, i drive very light footed and dont thrash it, but im getting around 180kms out of a full tank where as with the stocky i got 350, i have tried switching fuels i have tried the e10, 95, and 98, and only a few kms difference is this normal???
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Might have to put it back on? O.o until you can get extractors? Im guessing your a P plater so no extractors for you..:\
    My car gets 400ODD k's from a full tank with only a lukey 2 1/2" catback.. :\
    Mar 2011
    sydney
    VS Executive S2
    Aug 2010
    melb
    I too wanted to throw on a more free flowing exhaust to improve my fuel economy.
    But after speaking to a few exhaust places, they have advised me that a free flowing exhaust will improve highway fuel economy and will NOT benefit an attempt to achieve better fuel economy around town/city driving. 90% of my driving is city traffic so i chose to leave the stock exhaust on as per their recommendation.
    What type of driving are you doing? Mainly highway? Slow stop start city traffic???
    Mar 2011
    sydney
    VS Executive S2
    Aug 2010
    melb
    Well there you go.
    Do what i did, speak to a few exhaust places and get their opinions. ALL of them told me the same thing:
    Free flowing exhaust - improved highway economy / reduced town, city economy
    In other words, it would reduce my economy. Once again, every exhaust place i went to told me this.
    Mar 2011
    sydney
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Still should be getting more than 180k though.. My stock VR would get around 400...
    VS Stato l67
    Mar 2009
    Melb
    Your probably putting the foot down more when accelerating to make up for the power loss from the bigger exhaust. That wouldn't be helping the economy either
    Mar 2011
    sydney
    VS Executive S2
    Aug 2010
    melb
    Quote Originally Posted by brend94vr View Post
    guess the only thing i can do is get a long range fuel tank then
    You'll still use the same amount of fuel.
    Is it really worth having the aftermarket exhaust on? Is it really providing that much more power?
    I personally choose fuel economy over power.
    I'd rather save money and fill up less often then have slightly more power to drag off a bus.
    Mar 2011
    sydney
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    But if you leave it on your doubling the amount of fuel you use.
    More fuel, less k's, more times to fill up = waste of money in the long run.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check they didn't move the oxygen sensor location - if they did the engine will run in open loop or closed loop (I always get them mixed up) which will mean you use much more fuel. Also check you coolant temp sensor which tells the ECU when the engine has reached operating temperature....if it's buggered it will think the engine is cold and feed more fuel in.
  15. #15
    Mar 2011
    sydney
    i think the oxygen sensor is the problem have had the check engine light come on and go after i stopped
  16. #16
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    That will be the reason for the extra fuel used. Get it fixed soon as the excess fuel will damage the catalytic converter. New sensors are on Ebay pretty cheap...VR has 1 from memory.
  17. #17
    Mar 2011
    sydney
  18. #18
    vx s pack II
    Jan 2010
    aLKIDA
    Check for codes bridge pins 5&6 on the diagnostic connector.
    You can check if the 02 sensor is working or not With a multi meter.
    The best way is to check the 02 would be on a graph.
    Owe and for hako its open loop when the o2 does not work.
  19. #19
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by PRAVX II S View Post
    Just got to remember which is which!....so in open loop the ECU uses a default figure?
  20. #20
    stuntmanmike's Avatar
    stuntmanmike is offline Car wotsit & stuff
    VP 3.8 V6 Auto and VS BT1 5.0
    Jun 2009
    At home on planet earth...
    A 2-1/2" system is a little too big for a stockie V6. A 2-1/4" is better for street duties. Anyway...
    The "faulty O2 sensor" code might not show up using the diagnostic mode.
    My V6 has a 2-1/4" free flowing system and on closed throttle the "engine alert light" used to illuminate. Blipping the throttle would turn off the "engine alert" light.
    I reckon your fuel consumption has gone to the dogs coz your O2 sensor is not feeding the inputs to the ECM the way it should.
    FYI having silicon go through the engine will stuff a O2 sensor in no time.
    Maybe try a new O2 sensor firstly like the others are suggesting. If that does not work or change your fuel consumption then maybe consider selling the 2-1/2" set up and use the funds to offset the purchase of a 2-1/4" system. The 2-1/2" system will work well with a stockie 5 litre.
    Best of luck...
  21. #21
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by stuntmanmike View Post
    maybe consider selling the 2-1/2" set up and use the funds to offset the purchase of a 2-1/4" system...
    A couple of hits with a hammer to flatten the pipe a bit works the same!
  22. #22
    holden commodore super 6
    Sep 2011
    delahey
    Pipes way to big exhaust centre should of known better. Maybe change ur sensor and see if that helps. Better doing that than changing the hole system back and see what happens. But thats shocking fuel consumption. Even though it's stock maybe memcal.
  23. #23
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by hako View Post
    Well think of a electrical circuit with a light globe when its OPEN circuit the light will not work (open loop condition)
    Now the circuit is closed the light globe glows (closed loop condition)
    Open loop will still use other sensors other then the o2 sensor, Like ECT,TP,MAP,RPM to deliver the right amount of fuel.
    When the o2 is at operating temp and see's cross counts its in closed loop and can fine tune the fuel delivery via feedback.
  24. #24
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Thanks - the open/closed bit makes sense. I'll read up on O2 sensors....didn't realise they could make as great a difference in fuel consumption as the OP is experiencing.
  25. #25
    vx s pack II
    Jan 2010
    aLKIDA
    Well we are not sure if the o2 sensor is at fault. Remember its a o2 sensor it sences how much o2 is left.
    you would need to put it on a graph and see the cross counts and how far apart they are also the voltage coming out of it.
    If the o2 is stuck on lean the ecu will make the injector pulse wider. hence the fuel issue.
  1. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  2. Recommended Fuel for Vy to increase fuel economy
    By redlion05 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2011, 04:30 PM
  3. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 10:24 PM
  4. Bad fuel economy, strong fuel smell?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 08:43 PM
  5. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-05-2007, 09:39 AM
