Results 1 to 4 of 4
Thread: Interchangerble tranny
    94' V6 VR UTE 4SP AUTO
    Sep 2011
    Drouin (VIC)
    Default Interchangerble tranny
    Hi,
    I am trouble trying to track down a 4hd 13 pin plug transmission for my ute, does anyone know if a 5hdd will fit, the wreckers are all saying differently what can i put in if i cant find a 4hd and i don't really want to go manual.
    cherss.
    WH Stato
    Jul 2004
    Moorabbin
    A 4HDD can only be replaced with a 4HDD, it's only the 5-6-7HDD that will retro fit with each other!
    We have a 4HDD with 174,000 genuine k in stock but they are generally hard to find in good condition, it all comes down to how much you want to spend!
    <a href=http://totalcommspares.com.au target=_blank>http://totalcommspares.com.au</a>
    Sep 2011
    Drouin (VIC)
    A tranny specialist told me that it is a a 4HD tranny (with a 13 pin plug 1 solenoid for overdrive and 1 solenoid for TC lockup), not a 4HDD (with a 12 pin plug 1 solenoid for overdrive an TC lockup combined), all the wreckers are telling me differentlly some know about that and others don't. If i put a 12 pin 4HDD in my TC won't lock up. The only other optionseems to bea vn-vp vaccum tranny or a manual but it's a bit of mucking around.
    I'm not sure what to do!!!!
    WH Stato
    Jul 2004
    Moorabbin
    Quote Originally Posted by Holden94 View Post
    First thing I'd do is check for yourself, look at the bellhousing behind the LH head, there should be a sticker there designating what transmission it is, failing that the code is stamped on the trans body RH side just above the sump, can be hard to see without a hoist though.
    I have only 2 listings for VR V6 Ute & they're both 4HDD (floor shift).
  1. tranny help
    By atomicSS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2011, 09:56 PM
  2. How Much Tranny
    By COMMY VP 666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-01-2009, 03:02 PM
  3. Tranny on its way out?
    By VZHSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-05-2008, 10:09 PM
  4. vl tranny into vk
    By commo69 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-04-2007, 07:22 PM
