Results 1 to 13 of 13
Thread: running real ruff plz help!!!
    vs ute
    Aug 2011
    gold coast
    Default running real ruff plz help!!!
    hi guys, i have a vs, v6 ute, a while she was running real ruff slatters on throttle idling ruff just didnt wont to go so i bought all new fuel fillter, fuel pump, leads, and ran some injector cleaner through it ...then it came down to replacing coils and dfi,, then she ran perfect, just the other day i had a little accident with my extractors, i have just got my car back from putting new ones on and now it doing it all over again and im outta ideas... i also have been running bp ultimate THE GOOD FUEL so i just dnt no plz help!!!!!!!!
    VS S-Pack SII
    May 2008
    have you checked for error codes?
    youve changed your extractors... did you damage the oxy sensors?
    vs ute
    Aug 2011
    gold coast
    i havnt done error check. how do i go buy doing that.. and wouldnt the exhurst ppl be able to tell if oxy sensor are stuffed...mayby i should go back and see them
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by quick six View Post
    You have to test the o2 sensor on a graph or multimeter. If the job was installing extractors then thats all they will do.
    The o2 sensor just screws in and the electrical connector just plugs in.
    Might be a leak in the exhaust manifold/extractors they installed.
    Check for vacuum leaks
    Check if the intake duct has no leaks.
    Check the maf sensor.
    vs ute
    Aug 2011
    gold coast
    vx s pack II
    Jan 2010
    aLKIDA
    wat is a maf sensor... and wats best way to cheack for vac leaks
    Look at the picture the vacuum lines are behind the inlet manifold and MAF sensor is obvious.
    vs ute
    Aug 2011
    gold coast
    aww sweet.. es i will be cheacking that thanks heaps mate... wat do u say bout the o2 sensors should i take it back and get them cheacked...
    vx s pack II
    Jan 2010
    aLKIDA
    Well first of check for codes before you go any where.
    bridge pins 5&6 on the diagnostic connector and see what you get.
    There is a right up on this some where on the forum have a search.
    Also you can use a multi meter to test the o2 sensor,but the best way to test it is on a graph.
    I dont think the o2 sensor is your problem. Because the o2 sensor only works when its heated up to its operated temp.
    Does your car idle rough straight away from cold start?
    vs ute
    Aug 2011
    gold coast
    yes but not as bad as when it warms up a bit
    thats where it starts to miss, but sometimes ony slightly
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Here mate
    Great writeup and it has pics.
    Good luck.
    Checking error codes VR/VS (Revised)
    And here is what they mean.
    http://www.justcommodores.com.au/art...omputer_v6.php
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    vs ute
    Aug 2011
    gold coast
    ok i have done error checks and it showed 12 system pass, any other ideas haha
    VS Exec
    Mar 2011
    NZ
    check for good compression. Make sure all tour leads and injectors etc are plugged in securely. if all ok maybe a fuel flow test, but only if there are no inlet / exhaust leaks. inlet leaks can be found by spraying round with engine start while idling, if there is a leak the engine will pick up a little as it sucks some in.
    vs ute
    Aug 2011
    gold coast
    thanks heaps guys.... it turned out to be the spark plags.. 2 of the plugs were cracked on drivers side, must of been inpacked when i damaged extractors..... she runing brand new.......
  1. Running ruff.
    By brainless in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-02-2011, 06:10 PM
  2. vs supercharger running real ruff..
    By mz-v6-2c in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2010, 08:34 PM
  3. VN Commodore S suddenly running ruff
    By jakewaze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2009, 12:47 PM
  4. vl turbo running ruff
    By vlturbs in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-09-2008, 09:28 PM
  5. running ruff
    By vpssguy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2007, 03:53 PM
