long story short iv had the thrust bearing and carrier and spiggot bearing replaced and my clutch still wines when fully engaged in gear and this afternoon after work has started to do it in neutral any ideas as to what it could possibly be?
When it is in neutral with the clutch engaged, if you disengage the clutch does the sound go away?........if so, does it come back immediately you engage it again.
if in gear when the clutch is out (foot not on pedal) all holden gear boxes have a whine in first gear, but if it is only when you press the clutch in and it whines maybe its a bearing of sorts.
