My car shudders when clutch is completly out when in first and second gears only.
anyone have an idea of what could cause this to happen?????
have you just replcaed the clutch?
Shoulds like a bearing.
VR and VS error codes:
VS V8 DTC/Error codes comprehensive list.
VS V6 DTC/Error codes comprehensive list.
just talked to one of me mates and think it might be my diff, and now its doing it in all gears now
Try your centre bearing....
Had this problem with VR Exec V6, it turned out the Tailshaft had been hit and through it out a bit and the clutch plate had been torqued in correctly.
Does the pedal shutter under load???
Could be dirty or worn clutch plate.
