Results 1 to 3 of 3
Thread: Removing Front and Back windows ?
    despo's Avatar
    despo is offline V Fast S furious
    vs series one
    Jun 2009
    Default Removing Front and Back windows ?
    Anyone know how to do this on a vs? taking the plastic strip around the outside but seems like its glued underneath as well, any trick to pulling them out ?
    or am i going to have to smash it to remove it ?
    cheers
    VR wagon, 5 ltr ski boat,
    Sep 2009
    Broome
    If your talking about the Rear door windows. The 1/4 window has to come out 1st. Lower the main glass, remover the guide rubber next to the top 1/4 window and there are 2 screws. remover the guide at the bottom and the whole 1/4 window will slide forward, tilt the top and remove the 1/4 window assy. then remove th the main glass.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If you mean front and rear windscreens, once the trim is off you need to cut them out and glue them back in.
  1. Removing front seat back panel and head restraints
    By Calaber in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-10-2010, 01:45 PM
  2. Removing Rear Windows, HOW???
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2009, 10:46 PM
  3. Front pwr windows only, but want rear pwr windows.
    By pjdm1980 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2009, 12:39 PM
  4. Removing front and rear windows in 1 piece
    By DANNY8 in forum General
    Last Post: 10-05-2009, 07:20 AM
  5. removing front/rear windows + roof spacer
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-10-2008, 08:24 PM
