Results 1 to 6 of 6
Thread: engine temperature not working
    VS berlina
    Aug 2011
    Default engine temperature not working
    need help fellas.
    my engine temp isnt working. id like to know what places to check. i dont know where the sensor is on the engine
    its on a 1997 VS commodore
    vs commodore
    Oct 2009
    Tamworth NSW
    Check the temp sensor wiring connectors. The V6 has the temp gauge sender unit at the front of the engine just below the thermostat housing where the top radiator hose connects to the engine.. Theres two temp sensors there, ones for the temp gauge, which is actually known as a sender unit, and has a single wire connected to it. The other temp sensor has a couple of wires going to its connector, and this one is used by the ECU so it knows the engines temperature... Im not too sure about the location of these on the V8s though.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Try giving the dash a bit of a hit before assuming the sensors are not working... Sometimes they get stuck or there is a bad connection in the cluster....
    VS S-Pack SII
    May 2008
    Quote Originally Posted by James39 View Post
    Mine does this... One day, i'll pull the cluster out and clean the connections on the back... I think it's a bad connection between the gauge posts and the circuit pad on the back (The copper nuts maybe loose/corroded??)
    It's quite an easy job... I'm just lazy... but when it's not working.. a firm tap on the Dash above it... and it kicks into life.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    Quote Originally Posted by PanthaVS View Post
    bad solder joint in the cluster. will happen to every vn-vs at some stage.
    VSII Manta
    Apr 2011
    Erica VIC
    Did ya try bashing it?? It happened in both my VR exec and VS Ute
LinkBacks (?)
  1. 18-11-2011, 06:01 AM
  1. Fuel And Temperature Gauges Not Working Properly
    By Hungrytoheal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2010, 04:25 PM
  2. engine temperature.
    By Tony. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2010, 09:09 PM
  3. Engine Temperature on VZ SS
    By BLACK VZ SS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-08-2008, 02:19 AM
  4. VN Temperature gauge not working
    By IvegotaCommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2007, 12:59 PM
  5. Engine temperature
    By grosshom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2005, 01:03 AM
