Just wondering if any one has experienced this problem. ML60 auto has no 1st gear or 4th gear at all. Selecting D will take off in 3rd, if you select 2nd position it takes off in 2nd then will shift to 3rd fine but has no overdrive I removed pan & checked a couple of solenoids & it all looks pretty good, no burnt oil or excess wear found. I am thinking its electrical ?
I found a blown fuse which was for transmission but it didnt improve operation & it hasnt blown since.
Any help is appreciated
Sounds like to me that it's your shifting solenoids
1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
Thanx MM57VX Do you know which solenoids are for 1st & 4th ? There are 5 altogether & I checked the 2 back ones & they are both fine
There's 2 shift solenoids in the box it self, u mite as well do a service on the box while ur replacing the solenoids because their under the oil filter, I think from memory it's roughly 100 for solenoids and a service kit
With oil but that's doing it your self
Your car is in Limp Home Mode (LHM) which a safe mode that the ECU uses when there is damage or the risk of damage to the transmission. You need to check for error codes as per this link. The error code will tell you exactly what the problem is. It probably is a solenoid but the error code will tell you which solenoid.
Checking error codes VR/VS (Revised)
Mine was doing this. It was a 7HDD box. The error codes it gave me were: 59, 66, 67, 73, 83.
Installed a 6HDD and TC (different to the one that was in there) and the problem was solved.
The engine was not what caused the transmission to do that due to it was a new engine we just put in.
$100 for every solenoid? Id love to know where you would get that from as the pressure control solenoid is not cheap.. The cheapest iv need the complete solenoid package and wiring harness is $250.
Service kit is fun to do, removing and installing that filter holder piece. Easier with the box out and rolled over.
VR and VS error codes:
VS V8 DTC/Error codes comprehensive list.
VS V6 DTC/Error codes comprehensive list.
