Results 1 to 8 of 8
Thread: gas - important
    Dec 2007
    Default gas - important
    hi
    when you put gas in the tank and you hear a air leak in the valve on the middle of the filler neck where the bowser hose connects is that a major problem or is everything ok
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    There is a one way valve at the gas filler connection and a 2nd one way valve in the tank.
    When you remove the gas filler nozzle, you are having the gas leaking out from the gas filler to the tank.
    If this is happening, you should have it checked by a gas expert. Maybe a seal or spring requires replacing.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    when is ur gas system due for service?
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    Dec 2007
    Dec 2007
    Dec 2007
    VK EXEC EFI
    Jul 2006
    Not the sorta thing you wanna be unsure about, grab a mate whos got lpg and drag them down the servo and get them to have a listen. If they reckon its not right get a professional to have a squiz.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    sounds like the filler valve seal is leaking maybe be due to dirt or grit in the seal or the seal is split , filler valve needs to be looked at or replaced , the only gas to escape will be the contents of the fill line , or maybe the filler itself is loose on its threads either way repair or replace the filler .
  1. Important Research
    By Deutscher in forum Jokes/Humour
    Last Post: 22-10-2009, 04:19 PM
  2. How important is getting your car serviced?
    By Siliconslick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-04-2009, 06:11 AM
  3. what is more important to you?!
    By jet_pilot in forum General
    Last Post: 29-01-2008, 04:02 AM
  4. more important (Go or Show)
    By flyen in forum General
    Last Post: 23-05-2006, 07:56 PM
