Results 1 to 6 of 6
Thread: Bcm fuse?!?!?!?!
    VK Berlina/VX S Pac
    Jan 2010
    Central Coast
    Default Bcm fuse?!?!?!?!
    Straight up, does anyone know where the freaking BCM fuse is in a VS Statesman?
    Is it actually called that or something else?
    Cause I'm trying to reset the BCM and its really starting to piss me off!!!!
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by MY_84_VK View Post
    As far as im aware, it should be listed under power windows, mirrors etc..
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    Not sure of fuse location but maybe you can disconnect battery and let power drain. I read here ages ago people put foot on brake with battery out or remove engine fuse to reset BCM. May be different on Stato though!
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Do you mean the ECU? Why are you trying to reset it? Clear error codes or something?
    VK Berlina/VX S Pac
    Jan 2010
    Central Coast
    Cheers for the replies, I'm trying to reset it cause of the stupid variotronic steering crap with the speed sensor, I'm pressuming its rooted but I thought I'd try that to see if it would make a difference. I found out how to reset it, by removing the bcm fuse, but it won't tell me where it is!!!
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Just disconnect the battery.
  1. WTB Small Relay/Fuse box, with only main fuse.
    By ShawtyNate in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2011, 10:41 PM
  2. My fuse for the dash lights is blowing (number 1 - 15amp fuse)
    By aussie7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 06:10 PM
  3. vl fuse box
    By BIG DYL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-03-2010, 07:50 PM
  4. fuse help
    By buster1192 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2009, 04:24 PM
  5. Where is the fuse bos?
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-07-2005, 10:09 PM
Tags for this Thread
