Results 1 to 6 of 6
Thread: VS Power Steering Problem?
    VR
    Jun 2011
    Syd
    Default VS Power Steering Problem?
    Yo,
    When using power steering 'excessively' eg. turning the wheel while idling, rolling around roundabouts my VS Equipe drops out and turns off.
    Initial thoughts are revs are too low but wanted a second opinion,
    any ideas?
    cheeeeers
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    VY SS
    May 2011
    Auckland
    If you take the serpentine belt off does the pump spin reasonably freely? Pump could be dodge
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Does this happen when not moving while in park or Drive?
    If this only happens on roundabouts then it could be the fuel return line in the tank is broken...
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd clean the throttle body and the Idle Air control valve (IAC) - it's both of these devices that maintain the idle speed of your engine when additional loads like turning aircon on or excessive steering actions pull the engine idle down.
    There is a "how-to" on doing these jobs.
    If it happens only when the fuel tanks is under 1/2 then I'd go with James39's advice.
    VR
    Jun 2011
    Syd
    Yeah, I've noticed when there's more fuel in the tank it happens less frequently.
    It happens irregularly, like, turning corners after the corner it drops out a bit. If i put my foot into it it doesn't do it as much.
    Tried to simulate it by sitting still and turning the wheel full lock both ways but couldn't get it to stall or anything..
    Thanks..
  1. VZ SS Power Steering problem
    By loudvtss in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-05-2012, 07:28 PM
  2. power steering problem?
    By Shaun80 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2011, 11:25 PM
  3. power steering problem..
    By 96 Calais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-12-2010, 07:32 PM
  4. Power Steering Problem
    By Trevor 062 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-12-2010, 02:18 PM
  5. power steering problem
    By BUSTA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2006, 10:45 PM
