Results 1 to 6 of 6
Thread: VS V6 not holding revs
    VS berlina
    Aug 2011
    Default VS V6 not holding revs
    revs seem a bit low on neutral. just under 1 when it used to be over. engine sounds like it skips a bit too.
    and also it did stall when i was driving and it is an automatic trans.
    what could be the problem?
    vs commodore
    Oct 2009
    Tamworth NSW
    Try checking for any logged error codes in the ECU. Heres a link to a page that shows you how to do this simple test, which will show if anything is wrong or faulty with the engine management systems..
    ---Checking error codes VR/VS (Revised)---
    VS berlina
    Aug 2011
    i just checked it. it added up to 12 and says everything is fine. also took it out for a drive and the trans light went on. i have a brand new lukey exhaust on it and i could smell that. somethings wrong here
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Recheck the codes - read the instructions again - if the engine/trans light is coming on it will leave a error code.
    vs commodore
    Oct 2009
    Tamworth NSW
    Did you let it go through for a bit because the test will show up a code 12 three times, and will then then flash up any logged error codes , thats if any codes are logged of course ,otherwise it will just continually flash up code 12. Also, if the battery has been disconnected,any logged codes will be deleted. This is how you remove any logged codes, by disconnecting the negative battery terminal for a minute or two.
    vs commodore ute
    Oct 2011
    adelaide
    throttlebody adjustment
LinkBacks (?)
  1. cam holding back power
    By moco in forum General
    Last Post: 01-03-2010, 03:18 PM
  2. Handbrake not holding
    By skookumchuck in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-11-2009, 11:09 PM
  3. Holding Revs
    By vt s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2009, 03:02 PM
  4. VT v6 5spd engine holding revs when i clutch it
    By xx1600xx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2008, 09:02 AM
  5. VL Automatic holding 1st when cold
    By rx3 madman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-04-2006, 09:18 AM
