Results 1 to 15 of 15
Thread: VR lvl 3 cluster screwed!
    '94 Holden Calais VR V8
    Jan 2009
    Western Suburbs, Melb
    Default VR lvl 3 cluster screwed!
    My speedo light bulb blew a while ago but the two side ones were working up until recently. They ended up going out too but everytime I smacked the top of the dash they would come back on. The other day I was driving and I started smelling like an electrical burn and noticed the all 3 globes were out any way changed them all today and nothing. Checked all the fuses and contacts everything was good but still no luck.... Wondering if any could shed some light!!!
    Jan 2009
    Can anyone help? I wanna see if I can't find the problem before going to an auto elec
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    First things first, do the globes just not work or has the entire cluster died/do any of the gauges/needles work?
    Take your cluster out, and have a detailed look at the Green Plastic Membrane which covers the back of the cluster (and has all the copper lines running from the plugs to the various functions of the cluster...
    Check for any damage of any kind, breaks in the copper tracks etc...
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    Jan 2009
    Just the globes don't work and I had a look behind the cluster and the membranes seem like they are all making contact and don't see any burns in it either
    VS Berlina/ KJ Verada
    Sep 2006
    can the copper lines be fixed if there are score marks from twisting bulbs in and out?
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by SWE11L View Post
    Use a bit of alfoil and fold it over both sides of the PCB - you may need to take it half off to do this. Make sure the globe tags are not too tight or it will just rip it.
    Clean off any green coating if you need to make a contact a little way away from the main contact area where the globe goes in. Super glue alfoil in place once the globe is in. Hint once the globe holder is in place the bulb can be pulled out from the holder without taking it out of the cluster again so can be a perm't fix.
    I have made this repair several times when out and about fixing clusters for people.
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by SUSS8 View Post
    Are the globes blown - can happen. Swap fuse 1 over with another one see if that helps - I have seen fuses that look OK but still fail.
    Jan 2009
    88GreenVN's Avatar
    Jun 2006
    Swapped fuses around and changed new globes
    Then the cluster is not getting 12v to the globes or the earth is bad. From memory the brown white wire feed power to the globes. See if you have power at C2#4 with the parkers on.
    Jan 2009
    Just checked and it's got power by still won't turn on. If the headlights are off and I turn the key to ACC the lights flicker on and off really quick and that's it. Checked the back if the cluster and doesn't seem to be any burns or any bad connections so I'm stumped
    Jan 2009
    Still havent figured this out it's really annoying now. Any auto elecs on JC that could suggest anything really need the help!
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Jan 2009
    Quote Originally Posted by James39 View Post
    Might need to get another cluster to test things out?
    Been trying to get a hold of one but got no luck in getting one to borrow.
    Jan 2009
    Anyone know a decent auto elec in western suburbs? Still haven't worked it out and it's becoming difficult driving at night !!
  15. #15
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    instrument lights get powered from 2 sources on printed circuitboard so if all the lights are out it probably wouldnt be the tracks on the cluster.....probably 3 other potential sources of this fault.....wiring , headlamp switch or body control module.
    Does the dimmer work for the other lamps in the dash like the console etc other than the cluster?
    Illumination circuitry for the cluster lamps are fed straight 12v+ and the negative path is dimmed through the bcm electronics.
    The dimming circuit uses a grey wire in the return path from the negative of the cluster lamps to the bcm.
    Take out the dash cluster and try temporarily attaching a bit wire on instrument connector 2 terminal 5 (make sure it is on a grey wire) Thats the middle connector that sits in the plastic behind the cluster on the top row of terminals.....5 in from the left as you look at them and pluging the dash back in, turn the lights on and earthing this wire to metal of car...if instrument lights come on the fault will be either bcm or in the return path at least.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. Am I being screwed over here?
    By kcpwns in forum The Pub
    Last Post: 16-08-2011, 10:37 AM
  2. Is my DFI screwed?
    By dazza 38 in forum Electrical Wiring / Questions
    Last Post: 30-06-2009, 07:07 PM
  3. Am i being screwed? VN
    By vpete in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2008, 10:24 PM
  4. Did I get screwed?
    By Holdens Rule in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2007, 11:25 PM
  5. Screwed up weather
    By VS Omega in forum The Pub
    Last Post: 16-11-2006, 11:22 AM
