Results 1 to 12 of 12
Like Tree3Likes
  • 1 Post By nathanVY
  • 2 Post By Brett_jjj
Thread: Some advice ... Steering moaning
    VE Lumina
    Oct 2011
    Tanunda
    Default Some advice ... Steering moaning
    Hey guys/girls
    Just recently purchased a VR commodore and when I turn the steering wheel to the right it has a moaning sound anyone got any ideas on what that could be??
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    VE Lumina
    Oct 2011
    Tanunda
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    are you trying to say when you go to near or to full lock with the steering wheel?
    or just when you slightly turn it right?
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Before you go replacing the pump etc, get some rubber grease or WD40 and spray it down the grommet where the steering column meets the firewall, spray from the inside, turn the wheel a couple of times and spray again so it gets in there.
    Fixed the issue for me .
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    As above the gromet is most likely, but worn out sway bar link pin bushes can also make a groaning noise.
    VE Lumina
    Oct 2011
    Tanunda
    thanks will try tomorrow ....only when i turn slightly it happens Drawnnite......
    VS Executive S2
    Jun 2011
    Frankston
    if its just happening but everything seems normal, absolutely wd-40 or rubber grease, injected if possible
    vs commodore
    Oct 2009
    Tamworth NSW
    Yeah,Ive fixed this problem in a few peoples VS's now. When I first got my VS, it was moaning and groaning badly when the steering wheel was turned, I was told by a couple of different "so-called" mechanics that the P/S pump was on its last legs, or that the rack could need replacing or both. I then read on here about the rubber bush where the steering column passes through the firewall into the engine bay, and that spraying WD40 up in there from the engine bay side will stop the moaning groaning sounds. Well, that was a few years ago now, and the noise has never come back, the steering is still heaps quiet, and as I said at the start of the post, Ive made a few other VS owners very happy by fixing this noise as quickly and as easily as this for them. Some of these people were told the same thing by mechanics, that the P/S pump was stuffed etc etc. Thank god for JC, it saved me from spending cash on stuff that didnt even need replacing. Another thing is the moaning groaning sound thats made, it really does sound like a failing P/S pump, and I can see why people would think it was the P/S pump making the noise, I really didnt think a bush could make this kind of noise, but it definitely can..So if your steering in your VS is moaning and groaning when the steering wheel is turned, hit this bush with WD40 or similar first up before looking anywhere else.
    Mar 2004
    I used WD40/CRC and it fixed it for a while, but the noise came back. I was then told to use CRC silicone spray, its been 4 years and its still quiet.
    vs executive
    Aug 2011
    broken hill
    I've been putting up with my steering moaning and groaning for a few months now. I just packed the rubber grommet that the steering column passes thru and i worked a treat, now its so quiet, just like a a brand new one. Thanks heaps Just Commodores and thanks also to the people that post in these forums.
    VS SS
    Jan 2009
    WA
    Quote Originally Posted by nathanVS View Post
    This has also worked for me in the past
  1. berlina steering wheel controls advice please
    By qiken in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-06-2010, 09:30 PM
  2. VT SI Cracking steering issue!!! Need Advice..
    By dannyVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2010, 01:16 PM
  3. Moaning noise from engine
    By paddyj in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-03-2007, 05:10 PM
  4. Annoying moaning noise from engine
    By paddyj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-10-2006, 08:44 AM
  5. Strange 'moaning/squealing' from rearend
    By smaddock in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2006, 08:57 PM
