hey i have a vr v8 that has a leak coming from the front of the box i have already replaced the front main seal in it yesterday and its leaking still i was thinking it might be the tourque converter cause when i had a look at it yesteday the part where it seals is a bit worn like a slight channel where the seal sits any help would be great
thanks beau
Thats possable, you could try a speedy sleeve on the torque converter, being auto fluid and being very thin even a small groove can do it. Also it could be your new seal, i have had new seals leak because of defects in the seal, also when you take it apart again check and make shore you have not nocked off the spring on the back of the seal.
