Results 1 to 8 of 8
Thread: VS Senator Crazy Tacho and Grumpy Idle
    Brendo169's Avatar
    Brendo169 is offline HSV Porn
    VS Senator
    Aug 2009
    WA
    Default VS Senator Crazy Tacho and Grumpy Idle
    Hi there
    Ive got a few issues with the senator atm
    It seems to be really unhappy at idle and runs like a dog until it warms up. For example ill start it up and let it warm for a few minutes. Then when i start driving it is really unresponsive. Ill put my foot down a little more and nothing will happen for a few seconds and then it will kick in...then die a bit... really jerky
    Once warm the problem is gone
    Also when these symptoms are occuring the tacho jumps around like crazy
    There is no power loss
    No problems starting
    Replaced ignition module, coil and dizzy last year with genuine parts
    I did new leads last week but that didnt fix the problem
    Car is running a 355 stroker. Plugs are less than 5000kms old
    I might do the plugs this arvo and see how that goes
    But im struggling to place the cause of the jumping tacho
    i might check all the earths today aswell
    Brendo169's Avatar
    VS Senator
    Aug 2009
    WA
    what does everyone think
    i pulled the plugs and they look fine...so im going to leave them...all earths are good
    im thinking its one of the follwing
    coil
    dizzy
    ignition module
    my problem is that all three of these are less than a year old
    anyone got another ideas?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Sounds like could be the coil or dizzy cap. What did u do with ur old parts? and were they rooted or just swapped out for xxx reason. I would try them before spending your hard earned cash on a ignition module.
    Start it cold at night, give it a few revs and see if u can see any arcing in the engine bay around the high tension stuff. Unfortunatly as it seems you may have found out, these engines are hard to diagnose with any accuracy on faults to do with spark. Its more a caculated guess, pretty much following down the line from the ignition module to the spark plugs till you jag it.
    Just have a puruze over ur primary wiring on the coiul too, check its not rubbing or somthing.
    Reaper
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Brendo169's Avatar
    VS Senator
    Aug 2009
    WA
    alright chucked in a coil i had lying around and the problem was still there. so im leaning towards the module. would a faulty module be worse when cold or warm
    cus the car is undriveable cold. have to feather the throttle to keep it running and is almost normal when warmed up
    i thought ignition tended to worsen as the car heats up
    VrWagz1's Avatar
    May 2008
    wollongong
    With electrical issues, things generlly get worse as they warm. Mainly cause resistance increases with temperature. But if there is like a crack or somthing in a solder joint somwhere, the heat may help things expand and close the crack making it better.... But, if you have access to the module or a mates to swap out and test, i would give it a go.
    Reaper
    VS SS
    Jan 2009
    WA
    I had a rough idle,bouncy tacho.. felt like the engine was coughing and spluttering etc , Replaced the ignition module - Problem was solved
    Brendo169's Avatar
    VS Senator
    Aug 2009
    WA
    New ignition module fixed the problem. Cheers fellas
  1. Mean and grumpy
    By madsav in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-04-2011, 02:37 AM
  2. Replies: 8
    Last Post: 08-11-2010, 03:43 PM
  3. Vr senator tacho bouncing and missing
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2010, 04:53 PM
  4. Rough idle and tacho jumps slightly
    By jesse'sVT5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2010, 04:36 PM
  5. VS Senator V8 Idle Probs - Duel Fuel
    By deserthead in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2008, 05:58 PM
