Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By Wombles
Thread: Need help with coolant leak :(
    VS Berlina
    Apr 2011
    Ingham
    Unhappy Need help with coolant leak :(
    Hi. I bought this VS Berlina 1996 model just under a year ago and the previous owners pretty much were pretty careless with the vehicle and I've had nothing but trouble with this thing.
    I have this leaking coolant underneath, its not dripping from the oil sump but a little further towards the back of the car dripping off a tray looking thing? I'm sorry, pretty new to all this stuff and willing to learn. I cant for the life of me find out why its leaking or why coolant is even there?? anyways its leaking pretty badly like a fast dripping tap. Any help would be greatly appreciated
    VS UTE, HT MONARO REBUILD
    Dec 2010
    VS Berlina
    Apr 2011
    Ingham
    VE International 3.6L
    Jun 2011
    Gold Coast.
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    I was gonna say hoses or inlet manifold.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    So its pretty much dripping from the gearbox bellhousing inspection cover plate? If so this is not uncommon at all. Basically you need to replace the rear crank seal alloy plate and gasket. This is what seals two of the coolant passages at the rear of the block and with age and poor coolant condition the alloy plate slowly corrodes and the gasket disintegrates. The gearbox needs to be removed to replace this. New gasket and plate is approx $200.
    Cheers.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it is as Cander24 suggests, you may be better off adding a good quality brand of stop leak - this should stop the leak....temporarily maybe but it's not unusual for such repairs to last quite some time and it will certainly save you a lot of cash as removing the gearbox will cost quite a bit as it involves more than just undoing a few bolts and labour is about $90 per hour.
    However if you plan on keeping the car for many years then it may be better to do the permanent fix.....but you also say the previous owner neglected the car so this leak may just be the tip of the iceberg.
    VS Berlina
    Apr 2011
    Ingham
    Cander24's answer makes the most sense. still thinking of what action I will take on this... Any suggestions on a good stop leak??
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    There are quite a few stop-leaks to choose from, I guess the best way is to ask the bloke behind the counter which is the best one to buy - they will get complaints from customers when it doesn't work so they are not likely to sell you one that has bad rep.
    VS Berlina
    Apr 2011
    Ingham
    Okay. Well I'll let you's know how I go
    I just want to say thankyou guys for the help and advise it is greatly appreciated! cheers
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    If you have a NatRad radiator place near you, i think they do free pressure checks and diagnosis of the problem. I know the one near me is not to pushy about them then going and fixing it. If they are, just tell them its a bit expensive and you need a week or two However if u need parts it would be good to give them the curtosy of atleast buying the parts off them.
    Reaper
    VS Berlina
    Apr 2011
    Ingham
    I don't have a NatRad near me :/.
    Just letting you's know that I dropped the coolant and applied a seal-up (CarGo). done this yesterday and there had been no leaking "so far".
    See how we go
  1. vy ss BF coolant leak
    By rydogz in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-01-2011, 10:30 AM
  2. VX Coolant leak from Coolant Reserve?
    By anarklov3r in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 09:50 AM
  3. Coolant Leak
    By inais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2009, 11:19 AM
  4. Coolant leak
    By Domaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2009, 01:34 PM
  5. Coolant leak
    By jakewaze in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-04-2009, 11:40 PM
Tags for this Thread
