Hi guys,
my VR is lpg, and when i first purchased it i released who ever installed the lpg is a bloody idiot!
As you will see from the picture the mixer is right above the oil cap. (the converter is under that, also an awkward place to get to)
this makes topping up or a basic oil change a difficult task (two person job if i don't want to unscrew the air intake pipe)
I've put up with this for long enough its time to do something about it
Is it possible to switch over the rocker covers from left to right - right to left, will the bolt holes lines up etc
Any extra advice is also welcome
Cheers!
Yer there the same on each side when you change them just have a look as the gaskets/seals make sure there all right so it should only take about 20 minutes.
Thanks heap, that is what i was hoping to hear, i will get started on that asap!
