Most times when i put the clutch in,the gearboz starts making a weird noise and i get a strong vibration on the gear stick,it all goes when i let the clutch back out. The car still drives ok but i dont want to stuff the gear box,whats its problem?
WTB:VR/S HSV 250km/h speedo cluster
You will need to replace the oil. Or at the very least top it up. A thinner grade should suffice.....
If it goes away when you let the clutch up, that would indicate that is a clutch problem and not gearbox related. You could have a thrust bearing failing...or the pilot bearing ....or the clutch pressure plate distorted....or the driven plate distorted.
I'd get it up on a hoist and have a look....if that's not possible I'd take it to a clutch specialist or a driveline mechanic for their opinion. I wouldn't leave it too long as you can bet your bottom dollar it won't get better.
Dex2 ATF in a WC t5.
Gearbox needs to come out. Check release bearing and spigot bearing. But probably best to take it to somebody who knows what they are doing (like a mechanic). As Hako said, its not going to get better by its self, but will probably get much, much worse if you leave it.
Pretty much what hako said^^^^. I cant see the oil being the issue, but hey its cheap to rule out.
As above, vibrations are bad. They shorten the life of everything, so get it checked asap.
Aww crap,cheers guys,i'll look into a mechanic today
