Hey guys
I took the dash out recently and put it all back together and now the hazards/indicators dont work, I have checked the fuses and the blinker and even borrowed a blinker to test and still no change =/
I did a bit of searching and found that the hazard switch might be broken? I took the dash out again to recheck everything was connected etc and all seems fine
Any ideas?
Yeah just make sure you plugged the hazard switch back in. This happened to my mates car the other day after he had the fascia off and had to disconnect the hazard button.
Just make sure that's plugged in first, then get back to us...
Yeah completely plugged in mate =/
The fact that they stopped working only after you had the dash facia out indicates it is more than likely a connection problem. Pull the plug out and make sure it is clean and well seated.
You could try the good old WD-40 on the hazard light switch and plug![]()
I'll order another hazard light switch , may have broken it during removal?
Prob not a hassle to pick one up but I have a working spare if you need it champ.
95 VS Berlina
http://forums.justcommodores.com.au/...ml#post1891856
I need some statesman/ calais woodgrain for drivers side panel!!
if its not the hazard switch use a mulit meter to make sure the power hasnt been cut out somewhere along the way
yeah bottom line is, if that switch shit the tin then your blinkers wont work at all.. Got any mates with the same car? Borrow their switch to test it.
I had the same problem. Could be a screwy hazard switch. Try this... keep pushing the hazard switch in and out for about 10-15 secs, then test your indicators.
I was watching the auto-elec do it and i was like wtf? but it worked, so try it
Isn't the A/C switch plug the same size, pin etc as the Hazard switch plug???
