Results 1 to 6 of 6
Thread: Interior Light Not Working
    VS SSBodyKit
    Sep 2005
    Default Interior Light Not Working
    Hey Y'all,
    id appreciate any info on this matter.
    My interior light on my VR has stopped working when door opens or when i flick the switch.
    It had been working intermittently b4 but now theres nothing.
    Ive changed the bulb ( the old one was shorting which confused matters ) and got the voltmeter out on door sensors and they seem to be fine, plus the switch should still work neway??
    Patrio7's Avatar
    Patrio7 is offline 3Y3 K4N 5P33K 1337.
    '96 S1 VS Exec
    Jul 2005
    Perth, Como
    fuse? that or maybe a wire has come loose or off in the works somewhere? which is the other question, does the light earth or does it have a negitive wire going somewhere...
    attn Über geeks, i play Second life. Patrio Graysmark.
    VS SSBodyKit
    Sep 2005
    Default i reckon its a fuse
    checked the fuses under the dash and the fuse for light has blown.
    changing that should fix the problem.
    thanks
    rattattack1313 Guest
    Cool
    The interior light does have an earth on it.....also...be careful when changing the bulb that the positive wire doesn't short.......
    VRII Acclaim
    Jul 2005
    You need a multimeter. If you dont have one already get one because you can fix any electrical fault on your car with it. Once you have your hands on one measure the voltage on the connectors of the bulb. Chances are they wont say 12v. If they do the bulb is the problem. If they dont do a continuity check of the ground wire and then go from there. Message me if you get stuck.
    VS SSBodyKit
    Sep 2005
    a new fuse has solved the problem.
    when all else fails read the manual
  1. VR Interior Light Not working
    By gobrien002 in forum Electrical Wiring / Questions
    Last Post: 05-01-2010, 09:31 PM
  2. Interior Fan Not Working
    By mum with VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-01-2009, 07:15 PM
  3. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  4. Interior light not working
    By COWSPUD in forum Electrical Wiring / Questions
    Last Post: 31-03-2006, 09:30 AM
  5. VS Interior Fan not working
    By 1996vsman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2006, 09:34 PM
