Results 1 to 16 of 16
Like Tree3Likes
  • 1 Post By Morton
  • 2 Post By Not_An_Abba_Fan
Thread: Tailshaft bolts??
    VP commodore
    Jul 2011
    South Australia
    Default Tailshaft bolts??
    Hello i have a VR exec, 5 speed, and im in the middle of a diff swap and my tailshaft bolts will not come out?? i mean its like no size spanner i have will fit and no socket is small enough to wedge in, can any swing any ideas on how to get em off?
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can drop the centre bearing and support (mark it so it goes back in the exact same position) so that the universal is at an extreme angle allowing more room to lock a ring spanner onto the bolt head - also pays to grind the head of the spanner flat to get rid of the chamfer or lead in....this way you get maximum grip of the head. A hit with hammer on the head may also help. If you end up burring the head so the spanner won't grip you can weld the spanner to the head of the bolt.....or seeing as you're replacing the diff you could cut the head off with an angle grinder. Don't use a open end spanner as it will probably slip. Good Luck and keep the Bandaids handy.
    VP commodore
    Jul 2011
    South Australia
    Oh mate, i used an open ender, BAD MOVE!! rounded and 2 were weather weelded or lock tighted on, and i had to ring my mate for a 16mm spanner, so i used a hak say (blunt) and an hour or so later its off, this diff cost hours of time, my ratches keept braking, my spanners are like made in 3rd word and to top it all the brake lines wouldnt align and ,my stupid handbrake cable on the left is like seized or something, took me hours im also not small and im squeezing under a car that i feel would have collapsed if i keept it up! As for bandaids i needed em great advice im sorer than a chick in a saw trap! WORST NIGHT EVER!!
    Plus side ive got alot of before afters so i might post for peps who want standard to SL spring comparison.
    commodore
    Aug 2009
    australia
    maybe just remove the diff with the tailshaft still attached ,that way you will find it easier to do when its not under the car.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    This reminds me of at time I first did anything to one of my first cars about 12 years ago, I had to change the tail shaft but couldn't get a tool on the top bolt, so the car was stuck up on jacks in the driveway for two days until my mate could come over and help me, he laughed at me, jumped in the car and put it in neutral and turned the tail shaft by hand allowing access to the troublesome bolt.(facepalm)
    Quote Originally Posted by bogan_vk View Post
    That would require him to remove the entire diff housing and that means he would need tools. Judging by his post he wouldn't have the right ones to get that far
    And there is a lesson to be learnt here"psychotic46", buy a set of tools that don't break. I started out with a $99 Sidchrome set from Bunnings about 4 years ago and its done many things from a basic service to an entire engine conversion without fault....
    Nothing more frustrating then being caught out halfway through a job because you dont' have the right tool...
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Rubbish, they're impossible to remove out of the car, you need the car in gear or handbrake on to stop it turning.
    The rear nut is 15mm and designed to lock onto the diff pinion flange. No spanner required to keep it still. The bolts are 14mm designed for spannerz only, holden can supply new ones when you stuff yours up :-)
    The 1972 HQ Kingswood
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Quote Originally Posted by Morton View Post
    Are you kidding?
    almost laughable, in fact it is... ha ha ha ha
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by psychotic46 View Post
    Sounds like your tools are about as good as your typing/spelling skills.
    Visit my Facebook page
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    This is true.
    Cheap, fast, reliable.....you only get to choose two.
    commodore
    Aug 2009
    australia
    i have to disagree ,thats what a big vice ,hammers ,oxy set and the correct spanners are for and if all else fails a cold chisel and club hammer either way if it was mine it would be coming off no matter what in or out of the car, to the op sounds like you have f/all tools and just those cheap chinese junk tools,you really need some quality tools and to make sure you have everything required for the job before starting it ,theres nothing more frustrating than being caught short having to ring a mate to come over with a tool.
    GRPABT1's Avatar
    VN shitta
    Sep 2010
    The ville
    I think you guys are reading his post wrong, he means it's rubbish that they are impossible to remove
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by GRPABT1 View Post
    I think YOU are reading it wrong...
    "Rubbish, they're impossible to remove out of the car, you need the car in gear or handbrake on to stop it turning."
    That bit there says that he means exactly what people are reading.
    VP commodore
    Jul 2011
    South Australia
    I Just hack sawed it, and brought new tailshaft bolts and nuts.
    I agree my typing and tools suck out loud lol I wanna get a set of stanley's since i do this stuff all the time.
    I was gonna try vice grips but lol mine keep snappingopen and smashing my hands.
    I have a manual, and i put it in gear to do the bolts, it stiffend it but the shaft still span on me, also i left the tail till last, so my handbrake was already diconected, i use to be a Ford man in a ford diff it doesnt have drum handbrakes, there connected to the disc at the back.
    But i wanna thank everyone for the ideas and suggestions, in other threads use have been amazing and helpfull.
    Does anyone think i should do a before an after on the car being lowered i have photos, and the lowering question seems to be asked like twice a week?
  15. #15
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd say do it - this is a forum where members help each other and I'm pretty sure that what you can provide will be invaluable to others who contemplate lowering. Submit it to the "how to" section. Good Luck.
  16. #16
    VS Stato l67
    Mar 2009
    Melb
    I spent 300 on kinchrome metric sockets and open/ring ended spanners after destroying many sockets and bolts with my $20 supercheap set. Best money ive spent. The way I see it, all you need to do is 4 hours worth of a mechanics labour yourself and they're paid off
  1. Is the vx v6 tailshaft the same as the Gen3 tailshaft ?
    By comfortss in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2011, 11:48 PM
  2. Tailshaft To Diff Bolts Vl Borgwarner
    By Sik_Cordz in forum General Discussion
    Last Post: 21-06-2011, 05:02 PM
  3. Flyweel Bolts S1 (6 bolts) How Do i Remove? Reverse or Normal?
    By social in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2009, 10:54 AM
  4. separating tailshaft and tailshaft lengths
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 08:18 AM
  5. help tow bar bolts
    By kegzcp308 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-12-2005, 08:56 PM
