Results 1 to 15 of 15
Thread: No spark??? VR SS
    VR SS
    Oct 2011
    perth
    Default No spark??? VR SS
    hey, im new 2this only just registerd so any help would be great!.. anyway iv joined this because i need answers!! my car wont start..its a VR SS and last sunday i washed the engine bay and since then it wont start..its been left to dry right out but still nothing?? iv checked the spark pugs and thers no spark, i checked the ignition module in my brothers 5ltre and it worked but im havin trouble checkin the coil as its a bitch 2reach.. does any1 have any idears or have had this trouble before. any suggestions would be great as im not evan sure it is the coil??.....
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    The only time I washed my VS Calais V8 engine with a pressure sprayer I had the same problem. Turned out to be the coil - suggest you replace yours. Best done on a cold engine - which should not be a problem in your case !!!
    VR SS
    Oct 2011
    perth
    i was worried youd say that, i can barley touch it with my hand let alone tryin to remove it lol if i can fit a new1 i definately wont be putting it back where its surposed 2go..maybe on the firewall or somwere? ill have a look 2moronow, cheers mate!
    Aug 2004
    Best way is to remove the engine covers, tie back the heater hoses and place some foam or cushions on top of the engine and the front of the car. Lie across the top of the engine so that you can see what you are doing with the coil. If you are tall and thin you might be able to fit between the bonnet and the hydraulic bonnet support and achieve the same result.
    simmons001's Avatar
    simmons001 is offline I like VS Caprices
    WH Grange/VS Caprice S1 5.0
    Jul 2005
    coil i'd imagine
    I like VS Caprices so much, I bought 2... and a WH Grange!
    VR SS
    Oct 2011
    perth
    hey, yh it was the coil.. but iv got a almost new1 from a 308 that was lying around in garage so i put that on but now when its running it sounds realy nasty,like a loud tapping sound almost like theres no oil?? the part numbers on the coil are different but both look the same and should do the same job ay?
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    how long were u cranking it for to see if it would start? if it was a while the lifters could have bled down. or maybe the oil pump wont prime, if the oil light wont go out after startup that would be your problem id say
    in that case id unbolt the end bit on the oil pump where the filter screws on, take the gears out, pack them with vaseline and reassemble. that should restore oil pressure
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VR SS
    Oct 2011
    perth
    yh i did try and start it for some time, my uncle just said the same thing (sumthing about the tappets?) how do you recomend restoring the oil in there or do i just leave it runng for abit?
    ps the oil light dint evan come on..
    VS SS
    Jan 2009
    WA
    simmons001's Avatar
    Jul 2005
    Seems to be time for vs coils to fail... lots lately... still, 15yo, so did a good job.
    btw I have a spare ignitor... should i sell it or keep it as a spare? hmmm decisions
    Aug 2004
    Quote Originally Posted by Nicks VR SS View Post
    You should be using a Bosch MEC718 coil.
    VR SS
    Oct 2011
    perth
    yh ive bought 1 now, i only checked with the 1from the 308 2see if it was making a spark..i havnt started it yet thoe because its been making that noies, i searched abit on here and it deffantly sounds like the lifters have bled.. but as the engine was fine before i washed it,and the reason theres no oil in the lifters because i was trying to start it 2much, will i need 2flush the oil and replace with new with some of that nylon lifter stuff?? ..or is it just a case of letting it run for abit till its warm? (i dont wana just try it incase i mess them up because i no they have a hefty price tag!)
    VS 5L M5 VS 6L M6
    Apr 2009
    the lifters can take a while to pressurize again after they have bled down, maybe start it and up the revs a little bit to get more oil pressure up, if u really wanted to putting some lifter free in there then changing the oil after they come good wouldn't hurt but its not necessary
    Avoid cluey police
    VR SS
    Oct 2011
    perth
    cheers mate i tried it and as soon as the engine warmed the noise went ! ill try it again when the engine has cooled down but looks like the problems solved.. thanks again!
  15. #15
    99 Vs SS SeriesIII Ute
    Feb 2006
    Unhappy Vs Dead after engine wash
    Christmas Day disaster. My coil packed it in at the car wash, when my stupid other half thought he'd wash my engine. Engine was cool, cos only 2 mins down the road from wash. Tow truck later, to bring her home. Yesterday I changed my ignition module over with a friends and still no joy so secondary, is coil. No spark at coil. I pulled the coil out last night, and what a shit of a job, but she's out. It has fine cracks running between the bolt holes on both sides of it. So I'm hoping this is my problem.... Will have to ring the holden dealer when they open. Dam Christmas holidays....
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. vh no spark
    By redrags in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-08-2010, 07:43 PM
  3. VN 5L no spark
    By Noy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2009, 10:01 PM
  4. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
