Results 1 to 2 of 2
Thread: Vs door problems
    Vs Wagon
    Oct 2011
    Default Vs door problems
    this is hard to explain. the doors on my commy dont lock into position when there opened.
    depending on the angle im on they usually click at the first point then keep going till they're wide open
    and the slightest bit of wind will usually force the doors to close or open.
    there seems to be no grease on any of the doors hinges. all doors do the same thing but drivers door is
    the worst. it rather annoying and its my 4th commy and they've all had really solid doors unlike this one.
    how would i go about fixing this? just buy grease? should i take the pins out and cover them? any thing i can do?
    help appreciated.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My Commodore has the same problem but I've lived with it. I think you need to remove the door trims and the push the retaining hollow pin from the arm and then it pushes inside the door. Use a mirror to look back at where the 'stay' fits in the door jamb. It is nothing to do with the actual hinges.
    Not sure if it is repairable although just about anything can be fixed. Good Luck.
  1. door problems
    By luke23 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-06-2011, 06:31 PM
  2. door lock problems!
    By vzed in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-09-2010, 02:43 PM
  3. VZ Door locking Problems
    By rbarn38 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-02-2010, 07:05 PM
  4. VS door lock problems...
    By VSPantha in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2010, 08:42 PM
  5. removing door looms - having real problems
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2008, 07:34 PM
Tags for this Thread
