Results 1 to 15 of 15
Thread: No Spark VR V8 :/
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Default No Spark VR V8 :/
    So today on the weekend I notice my car was running rough, so this morning I decided to do a bit of self diagnosis so I started to unplug the injectors 1 by 1 and replacing the plug back on them as I went if the idle dropped obviously meaning they were fine.
    Turns out my car runs the same with 3 injectors unclipped??? So I decided to replace the fuel rail with another which has injectors that are fine and now for some stupid reason I have no spark!
    I checked all the fuses, switched over relays, replaced the coil pack and even the Ignition module and still nothing?
    I have obviously bumped something in the engine bay but IBF if I can figure out what
    Any idea as to what I should be looking at next (besides a new car)
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Coil pack on a 5.0L?
    So it cranks but no spark?
    Did you knock the plug off on the dizzy when you pulled the fuel rail out?
    Visit my Facebook page
    VS SS
    Jan 2009
    WA
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Sorry, I meant the Ignition Coil
    But whats weird is when I earth out a test light and touch the + on the coil the light comes on (normal) but it also lights up when I touch the - terminal also, I wouldn't have thought this would happen.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The positive and negative on the coil are mainly for identification, not actually positive and negative. One wire comes from the ignition side to the positive, the other from the distributor to the negative. This is a trigger wire that tells the coil when to fire, not really a negative or ground, so it will still have power as it is connected through the primary coil to the positive side. I'd be checking to make sure that wire is still attached to the distributor.
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Ok, I'll have another look but from memory they just head straight back into the loom and I thought it pulls its ground/trigger from the ECU?
    Im not getting any pulse at he injectors either?
    I just hope its not the Hall Effect Sensor....Prick to change...
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If you're not getting any injector pulse, did you blow the main engine fuse?
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Look at that one, and its fine..well looks that way....
    All this from changing a fuel rail... Fark cars do my head in.....
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I reckon a plug has come off or is loose. Nothing can really break or fail by just replacing a fuel rail.
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Yeah I removed and replaced he HES plug, but like you said I recon I have just bumped something or moved and earth over a dirty part of the car causing dodgy contacts...
    Just called my mechanic and his exact words were "STOP FARKING TOUCHING YOUR UTE!" and I couldn't agree more
    Push bikes for me here on out
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you havnt fitted 1 buggered injector thats got a direct short circuit as injectors and coil and module get power from the same place
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Quote Originally Posted by delcowizzid View Post
    How would I test that?
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Well I went out this morning to install a spare wiring harness in case I has a split wire somewhere and before I committed the the daunting task I decided to kick it in the guts to see if it had enough charge and if not id place it on a charger while im rewiring it all......And it started ???
    Maybe it was the immobilizer ???
    The only issue I have now is I have a really loud lifter noise? Not sure if that has to do with the fact I was cranking and cranking with with out the pump producing oil pressure or what? Not sure if it will go away either?
  15. #15
    VS SS
    Jan 2009
    WA
    Quote Originally Posted by 304runner View Post
    The noise should go away after its warmed up, Cranking it constantly bleeds the lifters .. Had similar problem
  1. No Spark -_-
    By Unfolded-V8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2011, 02:12 PM
  2. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  3. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  4. No Spark
    By parkvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2005, 10:43 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
