Results 1 to 5 of 5
Thread: Replacing blinker stalk on VR
    Hunter SS's Avatar
    Hunter SS is offline Growing Old Disgracefully
    2006 VE SS
    Mar 2009
    Upper Hunter Valley NSW
    Default Replacing blinker stalk on VR
    My son is having dramas with the blinker stalk on his VR Berlina, with the cruise control in particular. He's ordered a new one but is having issues removing the cover off the steering column... any advice on the best way to get it off besides breaking the damn thing
    Reviled did i live as evil i did deliveR
    • UNDERSTEER is when you hit the wall with the front of the car.
    • OVERSTEER is when you hit the wall with the rear.
    • HORSEPOWER is how fast you hit the wall.
    • TORQUE is how far you take the wall with you.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    remove all the screws from underneath the cover (there is four or five).
    will then need to manuovere the bottom cover around the ignition barrel.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    as above^^^^
    remove the screws in the bottom of the cover holding the 2 halves together, then it may take some gentle persuasion to seperate the halves cos from memory theres some plastic tabs holding them together. no drama if they break cos the screws will hold it together just fine
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    Hunter SS's Avatar
    2006 VE SS
    Mar 2009
    Thanks guys. He got it off without a lot of drama. Just waiting for the new one to arrive. Hopefully that will resolve the cruise control problems.
    <RaBBiT>'s Avatar
    <RaBBiT> is offline Follow the White RaBBiT>>
    95 VS Berlina 5.0,VN Wagon 5Spd 5.0L
    Nov 2007
    [SA]
    dropping the steering down helps alot
    If Barbie's so popular, why do you have to buy all her friends?
  1. windscreen stalk replacing with one from berlina
    By grossy69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2009, 09:45 PM
  2. Need help replacing VT indicator stalk
    By ford6779 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2008, 01:00 AM
  3. Replacing Indicator Stalk
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-12-2007, 10:50 AM
  4. Blinker Arm
    By KLatham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-04-2007, 02:49 PM
