Results 1 to 6 of 6
Thread: Ok so... Still no spark?
    VS SS
    Jan 2009
    WA
    Default Ok so... Still no spark?
    Distributor , Ignition module , Coil , Leads, Spark plugs
    have all been replaced. and still have no spark from the coil???
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Mine did this yesterday and I worked on it for about 6 hours and got no result.
    Went out here this morning to check if I had battery power left from cranking it so much and the thing started... The only thing I can think of that caused it was the immobiliser playing up. But just double check that you havnt bumped the hall effect sensor (clip on the dizzy) or the two earth wires coming out of the loom near the firewall...
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    VS SS
    Jan 2009
    WA
    Quote Originally Posted by BlackVXGTS View Post
    Did you replace the rotor button when you replaced the distributor?
    Yeah mate
    Also another problem i was having is my indicators/hazard lights werent working, I got my new switch today i put it in and only one side on the dash is working.. So not sure if this is all electrical?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Next on the list to change would be the dizzy. Give a second hand one a go for $50. Worst case, you can resell it for $50
    Hall effect sensors have a habit of breaking without reason or indication.
    The 1972 HQ Kingswood
    VS SS
    Jan 2009
    WA
    Quote Originally Posted by Morton View Post
    Been replaced already mate
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. vn v8 no spark? grr
    By Noy in forum V8 Development and Modification
    Last Post: 29-04-2010, 10:45 PM
  3. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  4. My vn has no spark
    By bullit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2006, 10:57 AM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
