Results 1 to 10 of 10
Thread: HELP?? VS executive 96 wont start =(
    vs executive s2
    Oct 2011
    Albion Park Rail
    Default HELP?? VS executive 96 wont start =(
    Need help this is doing my head in =( Recently just installed a dvd head deck last week had problems with the wires touching metal which blew the interior lighting, but that got sorted out pretty quickly. Sunday the rca's werent in and put them in, put everything back together and had the same problem as before and aswell as the trip comp fuse. changed the fuses and everything worked, turned off the car n went to turn it back on n had no reds and engine doesnt wont to start at all. Had a auto electrician come out today and he couldnt find the problem.. everything else works inside the car, doors lock, headlights even the head deck just have no reds n no start.. Any one help please???
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Make sure the key head is making proper contact with the key reader when the key is inserted in the ignition keyhole....also try pressing 'unlock' just before you turn the key. Is the central locking working?
    89 VN Exectutive
    Jan 2011
    vs executive s2
    Oct 2011
    Albion Park Rail
    vx s pack II
    Jan 2010
    aLKIDA
    vs executive s2
    Oct 2011
    Albion Park Rail
    VS Executive S2
    Jun 2011
    Frankston
    sounds dumb but.. have you checked the battery? like tested it for volts etc
    Jaymz's Avatar
    Jaymz is offline Donating Member
    VS Exec 1996
    May 2005
    Hamilton, NZ
    Probably a bit late, but next time try to cover all exposed wires with insulation tape and never, i repeat NEVER, work on anything electrical in your car with the battery connected. Seen too many people come to grief with blown fuses/computers because of that.
    Do you get any dash lights when you turn the ignition to ACC? Does the fuel pump wirr away?
    You won't like me when I'm angry. Because I always back up my rage with facts and documented sources. - The Credible Hulk
    Oct 2011
    look at the fuses under the steering colum i had thos problem once and it was just a blown ignition fuse...
    Nessie1996's Avatar
    Nessie1996 is offline Joel Ryan
    VS Executive S2
    Feb 2010
    My brother had some issues with his VR where the dash would light up but the car wouldn't even try to start (as in starter motor would NOT engage). Problem turned out to be the Crank Angle Sensor. Just a possibility. Does yours start some days and not others? or will it start in the morning and you drive somewhere, hop out, get back in and it wont start again? If so I think Crank Angle Sensor might be a contender.
  1. New Key now car wont start and cuts out when km's on cluster start flashing :(
    By rowiejoan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2011, 10:44 PM
  2. vs calais wont start unless i kit unlock before i start
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 06:40 PM
  3. [TAS] VP Executive wont start or run
    By VPSambo in forum General
    Last Post: 27-10-2010, 08:58 PM
  4. 94 Model VR Commodore V6 Executive Series 2 Wont Start
    By bubz187 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2010, 11:11 PM
