Hi Guy's, I'm a newbie, my problem is my vs commodore over revs when the engine has warmed up. I'ts fine when i start it up in the morning, the idle drops back and every things fine but when i kill the engine after I'ts been driven for a while and restart it, it over revs like crazy and the idle won't drop back, so what I've been doing is to turn the motor off again and restart until I'ts back to normal idle, so what the hell is goin on !!!!!! any help appreciated thanks.
Check for any logged error codes to make sure everything is ok with the engine management systems etc.. Below is a link to a post that shows you how to do this simple error check.
---Checking error codes VR/VS (Revised)---
Hi Brett, checked codes and all is ok ??
Sounds like your TPS might be sticking and the motor is staying on idle enrichment. Clean the throttlebody and make sure the cable is properly adjusted
Originally Posted by Reaper:
Originally Posted by Jecs:
Sometimes an ECU reset can fix all sorts of problems, disconnect the battery for 15 seconds and see how that goes.
Thanks guy's I'll try those things
