Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Like Tree10Likes
Thread: Weird buoy thing near left front wheel?
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    Default Weird buoy thing near left front wheel?
    Anybody have an idea of what a little buoy type thing is doing near my front left wheel?
    Sometimes if I reverse, and full lock, it touches my wheel and makes a grinding sorta sound :/
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Its the vtec base plate that regulates the nos boost controller float valve when the intake pressure reaches 900 cfm it opens to let extra air into your cd player to keep it cool and to stop you from blowing a tranny, better get it looked at quick smart.
    In all seriousness tho, i have no idea. Perhaps a photo?
    VY SS
    Jun 2006
    Albany
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    VS Executive S2
    Aug 2010
    melb
    Yep, what he said.
    You plug your vacuum into it when you're cleaning the interior of your car.
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    vacuum reservoir mate
    Normally they are broken so you prob should be able to push it out the way of the wheel.. You shouldn't notice it when you have the inner wheel gaurd in anyways?
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    You have the buoy thingy on one side, don't look on the other side because there is a girl thingy
    http://woteva.tk/
    If it ain't broke... I can break it for you
    VS Berlina/ KJ Verada
    Sep 2006
    Don't see how it could be hitting your wheel. Should be guards in the wheel arch, even without them it really shouldn't be close.
    I think it's basically "reserve" vacuum for the air con system?? So when the cars under heavy load it doesn't affect the aircon/ engine performance?? Can someone confirm?
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    VY SS
    Jun 2006
    Albany
    im pretty sure its mainly for the interior fan direction switch and brake booster, when you turn the car off you can press the brake pedal a couple times then it goes real hard and same for the fan direction switch you can change it a few times and hear the hissing then it stops.
    91 vn s
    Jun 2009
    Adelaide, SA
    ^exactly. it shouldnt be hitting - or anywhere near your wheel though, check for broken mounts or something
    vs commodore
    Oct 2009
    Tamworth NSW
    The brake booster will hold its own reserve of vacuum, enough for about 2 brake applications, then once this reserve vacuum is depleted, the brake pedal becomes harder to press in as theres no longer any vacuum assist.
    The vacuum reserve tank under the passenger side front guard is there to stop the heater controls from shifting positions when the car is under load going uphill or when accelerating heavily. This is because the interior heater position control flaps, and the heater tap, are all controlled by vacuum thats ported from the engines intake manifold, so its got a vacuum reserve tank there for when the vacuum gets low in the intake manifold. Otherwise the heater flaps and heater tap would be constantly changing positions whenever the vacuum level drops in the engine...Ive seen this happen before with these cars, they get a vacuum leak somewhere, this leak causes the vacuum level to drop quicker than it normally would when the car is under load etc, which then causes the heater controls to shift from either the face or windscreen demist position, to the floor position when accelerating heavily or when going up long steep hills etc. Then it will change back again to its original position once the vacuum has built back up strong enough to move the heater flaps back again.
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    Yeah, well it's definitely the vacuum reservior. I'd assume the mounts are broken then, because it's literally 10 centimetres away from my tyre. Cheers anyway guys, any idea on how to fix/ how much it'd cost?
    1996 VS Statesman 5ltr
    Jan 2012
    Castlemaine
    Their are two vacuum lines that come out of this tank, one goes into the firewall, where is the other one suppose to go?
    vs commodore
    Oct 2009
    Tamworth NSW
    I have just had a look at my VS and Ive only got one hose that comes from the vacuum reservoir (theres only 1 hose connector on the vacuum reservoir), this hose goes to the rear of the engine where it splits into 2 seperarate lines with a t-piece,one goes to the inlet manifold ( vacuum supply for the system), and the other goes in through the firewall. Theres a one way check valve on the vacuum line that T's off to the inlet manifold. I also noticed that the windscreen washer hose looks very similar to the vacuum hose, and they both run together along the passenger side of the car down to the front where the washer fluid reservoir and vacuum reservoir are located...
  15. #15
    Jan 2012
    Castlemaine
    Oh your a champ! This is great news! What happened was my fuel line split right above my ign coil and started to drop fuel on to and caught fire, (not even a week after I brought it) so I took it back the dealer and asked them to fix it (more like told them to) and ever since I have had this vacuum line with no apparent location, they have fixed the line from the manifold to firewall but not put a t-piece back in it, and now every time under load my climate heads to my feet :/ hope this fixes it
    What side of the one way valve do I put the t-piece in?
  16. #16
    aussie4life11's Avatar
    aussie4life11 is offline backyard argument starter
    94 vr 3.8l v6 Auto Series 2 Acclaim
    Oct 2011
    Geraldton, Western Australia
    well i think it should go on the manifold side of the t-piece otherwise either the vaccum tank will store the vac pressure and not be able to release or the otherside going into your firewall would give you the same problem and the vac tank would depressurise every time you turn your car off. IMO and i could be wrong
  17. #17
    Jan 2012
    Castlemaine
    Thanks Aussie, I tried both ways and still no joy, still goes to feet under load I'm running out of ideas :/
  18. #18
    VS Acclaim Series 2
    Oct 2011
    Perth - Cockburn
    Mine ended up falling off. Got a new one and tried to push it back on, it holds, but I still only get hot air out of the bottom of my footwells :/
  19. #19
    Oct 2011
  20. #20
    Jan 2012
    Castlemaine
    Yeah mate, I think so, can oust air thru fire wall, but not back thru into manifold
  21. #21
    vs commodore
    Oct 2009
    Tamworth NSW
  22. #22
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by seq4x4 View Post
    Quote Originally Posted by Krilnik View Post
    Yep, what he said.
    Quote Originally Posted by woteva View Post
    Lolz.....
  23. #23
    Jan 2012
    Castlemaine
    Quote Originally Posted by Brett_jjj View Post
    The white end of the one way check valve goes to the engine side.
    Yeah got it the right way then, cheers, brought all new vac lines and a new owv today, was going to change it all over this afternoon, but got rained out, when I'm changing the vac lines over I'm going to pop the vac tank out and pressure test it, I'll see how that goes, if still fail, then I'm buggered if I know
  24. #24
    Jan 2012
    Castlemaine
    Okay so all vacuum lines have been replaced, took vacuum tank out and inspected for cracks and holes, none. But still doing its feet under load sh!t, have put four actuators in it, (all second hand) all do the same thing, is it possible to get the actuators brand new still? Does anybody have a spare known working ones that I could purchase or at least use to test my system?
  25. #25
    VRCALAISS is offline Banned
    94 VR CALAIS 3.8L V6
    Jan 2011
    Morayfield,QLD
    i always thought that was the cop chip processor core.
  1. VP front wheel bearings - hub looks weird
    By Circlotron in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2011, 10:05 PM
  2. weird grinding/knocking in the left front wheel
    By vsowner94 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2011, 06:40 PM
  3. Weird rattle on front left corner
    By soop in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-10-2010, 03:25 PM
  4. noise from front left wheel
    By vpcommo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2009, 07:22 PM
  5. Does your left front wheel stick out more than the right?
    By torana9x in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2009, 08:08 PM
