Results 1 to 6 of 6
Thread: VR window regultor clips?
    VYII One Tonner
    Feb 2009
    Default VR window regultor clips?
    Hi Guys,
    Some class act decided it would be a good thing to bash in my front window of the ute one evening and I've finally gotten around to repairing it. I'm just about to fit the glass but can't think of anyway to get the window regulator clips fitting into the channels on the replacement windows.
    I've done a BMW318i electric replacement and just remembered they had a replaceable plastic clip that you fitted to the channel then pressed onto the window regulator.
    Is this a similar system as it seems that once the window is in the door channel that you can't maneuver into any position to get both plastic clips in?
    google search brings up lots about power windows in VR's but nothing for the low tech option.
    Thanks
    Mark
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Yeah its pretty easy, I did this to my Ute yesterday.
    One of the rubbers had snapped of half way up and when the window was wound up from all the way down , it would run between the outside of the rubber channel and the metal rail causing it to jam and then eventually pop the regulator of the slider....
    Anyways, You just slide your window in then place the window winder back on and wind it up or down to an area where you can pop the right hand side slider on first.... Once that's on, you just level the window with your left hand from underneath the window and wind the window up or down, which ever way untill it lines up and squeeze the window and regulator together with your palm on one side and your finders on the other...
    Hope this helps
    VYII One Tonner
    Feb 2009
    I'm a bit unclear..are you saying I don't need to get the clips or I do need to buy new ones and then use your method of popping the window together?
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Quote Originally Posted by fragmoider View Post
    Sorry, I went on a bit of a tangent and forgot to help with that one
    The clips should just slip in and out, nothing by rights should be stopping them from slipping out if the regulator isn't clipped into them... So use the plastic sliders from the old window....
    Do you have the old sliders still?
    VYII One Tonner
    Feb 2009
    Yep,
    the window was completely smashed and in a million pieces, the window channels just slipped off the regulator so all the little clips etc are intact.
    The replacement window had the channels already so I'm hoping to know the method to slip the whole thing in complete.
    So as it's a bit confusing the clips are on the regulator/winder mechanism not in the window channels. :-)
    VYII One Tonner
    Feb 2009
    I am almost there..
    Got the regulator clips off, window in now what is the best way to pop the regulator back into the clip?
    Just don't want to break the window while trying to squeeze the two things together.
  1. how to remove window winder, no clips
    By ad45 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-04-2010, 12:00 PM
  2. help with my window cross arm clips
    By James_yo7 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-03-2009, 01:14 PM
  3. Where tov buy these clips
    By RBBS1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2008, 06:37 PM
  4. Window Winder Clips
    By fazz1977 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-06-2006, 09:57 AM
  5. WTB: sunvisor clips for my vh
    By PEAKN6 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-12-2005, 01:05 PM
