Results 1 to 5 of 5
Thread: calais dash
    Dec 2007
    Default calais dash
    hi
    when installing a calais dash into a 96 vs executive
    1. what wires on the 4th plug do you need to hook up if you just want the bit that shows how far the caras been and light up when the rest of the dash lights up at night when the tail lights are on.
    2. how much modification needs to be done to the wiring in a vs exec to fit a l3 dash
    3. is the plug already hidden in a 96 vs exec
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The 'Tripin" thread is a great read on this.
    Just add the L3 plugs to the Exec loom
    No - the 4th plug wont be hidden.
    and 3 Dangerous non ABS VN's
    Dec 2007
    what wires do you add id you only want the digital speedo counter
    will a vr calais cluster work in a vs
    how would you add the plug that goes where the speed alert used to be and connect the wires already there
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by shonky12 View Post
    Orange white and black white wires as per the wire diagram will show the ODO.
    VR will work OK in VS - but your seat belt warning will be an air bag worning
    The speed alert is differnt wires and cant be used for the trip switch block add the to the loom by running extra long wires to the 4th plug and main dash loom by the drivers side (if your not removing the loom)
    Dec 2007
    so with the speed alert do you cut the plug off and join the wires to the leftover wires on the plug for the trip computer switch block in the vvr/vs
  1. [VIC] SWAP - SSL IRS springs for VT Calais door trims/Calais suede dash kit
    By sxc_sound in forum Swap / Wanted to Buy / Trade
    Last Post: 13-02-2011, 11:05 PM
  2. VK Calais digital dash to analog dash
    By mattw in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-12-2008, 08:16 PM
  3. vp calais dash loom into vn calais
    By calais_8 in forum Electrical Wiring / Questions
    Last Post: 17-07-2008, 12:57 AM
  4. vp how to change dash to calais dash
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2006, 07:35 PM
  5. l3 calais dash
    By fleet5ltr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2006, 12:04 PM
