Results 1 to 5 of 5
Thread: VR Statesman Central Locking
    VR Statesman
    Oct 2011
    Default VR Statesman Central Locking
    Hi Guys
    I have a small issue with my VR Statesman. On the weekend a mate asked if he could check out my car, I gave him the keys while we were eating inside, he went out and opened the car with the key (he didnt press the remote) and the alarm started going off. He told me all he done was press the remote after the alarm started and it went off. Now the central locking doesnt work at all even with the key. I press the remote and the lights flash for the alarm and the alarm still works, the car still starts but the central locks wont open with the remote or keys. Key will only open the drivers door, rest have to be open from inside.
    Sorry about the long post but I thought I should explain it well enough incase someone else has run into this problem or hopefully someone knows how to fix it. I have checked the fuses and they are fine.
    Thanks in advance.
    Michael.
    vs commodore
    Oct 2009
    Tamworth NSW
    Id try resetting the BCM. The BCM is reset by removing the fuel pump fuse for 1 second according to the VR workshop manual. The fuel pump fuse is located in the fuse box under the bonnet. I guess removing the negative battery terminal would also do the same thing. The manual says that once the fuse is reinstalled, resetting of the BCM can be confirmed by a clicking sound coming from the BCM, the interior light coming on, and the theft alert indicator flashing.
    VR Statesman
    Oct 2011
    Hi Brett
    Thanks for the reply mate, I tried the fuse and the negative but got no click or blinkers flashing so I don't think it is resetting, also took the door trim off and disconnected the lock to try that but still no luck. Where would I find the bcm unit to try break the thing lol driving me nuts.
    vs commodore
    Oct 2009
    Tamworth NSW
    The BCM is under the dash, up in behind/above the fuses under the steering column.
    VC SL/E A3300 ,Looking for a VL
    Mar 2011
    armadale Perth, Australia
    is it working now?
    Black_Stig
    If Cars could scream Rape, I'm sure yours just did because I just eye fuc&ed the shit out of the above images.
    MY 1980 VC SL/E Exhaust Note
  1. vs statesman central locking
    By BRAWT_4TH in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2010, 10:41 AM
  2. central locking
    By Pickle' in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2009, 08:30 PM
  3. Central Locking
    By Chopgaz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-04-2009, 04:11 PM
  4. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  5. central locking
    By spice_man2069 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2006, 10:29 AM
Tags for this Thread
