Results 1 to 18 of 18
Thread: VS Dash Not Working.
    '97 VS Commodore Wagon
    Jul 2011
    Default VS Dash Not Working.
    So the problem is that the speedometer, odometer and trip gauge aren't working, it's a L2 dash I took it out to replace a blown illumination bulb and I've already looked at this guide, found a broken copper track and done the exact same fix but still no dice.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Have you replaced the small cog in the speedo head? if it has lost a tooth the kms wont count up.
    and 3 Dangerous non ABS VN's
    Jul 2011
    No, it was working perfectly fine before I replaced the illumination bulb, I haven't gone that far to have the cluster in pieces everywhere.
    vs commodore ute
    Aug 2011
    cairns
    let me know when u fix it please as mine has been like this for a long time
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Just get another one from the wreckers and match the kms to the old one with a needle. Carefully click the little teeth up or down on the side of each number.
    Jul 2011
    I could always try that, hopefully it wouldn't be too much though.
    Whilst driving once I banged the top of the dash and the needle was jumping, so I don't think it could be the gears..
    I've done very similar to the picture on the How-To with the tape and aluminium foil, and it looks like it's making contact on the connection.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd pull it out again and reinstall making sure every connector is fully pushed home. Disconnect the battery first!.
    Jul 2011
    It's been a week and I finally got around to checking the odometer cog/gear, all is well and good as you can see..
    Jul 2011
    Took it up the road today and the speedo/odo STILL isn't working, I'm heading towards the speed sensor now.
    So where can I locate the speed sensor?
    VS Berlina
    Mar 2011
    Woodford QLD
    Quote Originally Posted by IBLOWN View Post
    The teeth on the side of each number on an electronic dash? You may want to rethink that one lol
    Jul 2011
    Once you take that white gear out you can just wind the odo back and forth..
    VS Berlina
    Mar 2011
    Woodford QLD
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by skappascrap View Post
    It can be done while it is still there as well, just depends where you are doing it from.....
    Jul 2011
    True.
    So where is the speed sensor located so I can have a look at that tomorrow.
  15. #15
    James39's Avatar
    Jul 2009
    Newcastle NSW
    True.
    Is this an auto? One would think if the speed sensor was not working the gearbox would not work.
  16. #16
    Jul 2011
    Yeah it's an auto, I'm pretty stumped on where the speed sensor would be or the exact problem is.
  17. #17
    James39's Avatar
    Jul 2009
    Newcastle NSW
    If the problem happened after you replaced the bulb then the cluster is at fault.
  18. #18
    Jul 2011
    Long bump but I thought I'd update with good news.
    The speedo is now working after a few more attempts of that guide about the broken tracks fix, here are the results and now the speedometer, odometer and trip meter are all working again perfectly.
    It turned out to be two of the tracks.
  1. Please please help - dash not working
    By quinny SS in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-05-2012, 06:34 PM
  2. vk dash not working
    By Owen in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-02-2011, 05:09 PM
  3. VY V6 Dash LCD not working
    By Cobra30 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-06-2010, 12:08 AM
  4. vk dash not working
    By VKCOMMO in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-08-2009, 09:29 PM
  5. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
