hiya all
i need to replace my right side read door handle does anyone have a write about it ?? Or can anyone help me out how to replace it ??
any help would greatly appreciate it
easy as mate, pull of all your door card. there is some screws, most of them you can see but there is also one behind the door lock pop up thing, you have to pull off the red tab to get at it, also you have to remove the window winder.
then there is just clips holding the card on, just pull it back slowly and it should pop off.
once you get the door card of there is a plastic dust cover thing, you need to cut the glue so that you can pull it off. then you should be able to see the door handle backing plate. there is a long clip that you need to pull out once you get it out the handle comes loose and you can just jiggle it around to get it out.
Not the best explanation, but you can search on the site for a better answer.
