Results 1 to 6 of 6
Thread: changing timing chain brands? and worth it?
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default changing timing chain brands? and worth it?
    hi my vs has done almost 160 000 k's and was wondering if its worth changing teh timing chain? theirs no noise etc but chains do stretch a bit don't they?
    ive seen 2 on ebay
    COMMODORE VR VS VT VX & VY V6 TIMING KIT .. NEW | eBay
    CS6VS Crow Timing Set Holden V6 Commodore VR VS VT VU | eBay
    the first on comes with the tensioner and the crow one comes with just the chain and sprockets.
    which would be better? obviously the crow ones but im not gonna be turboing it or supercharging it, i do however drive it hard, sometimes really hard
    also whats with the different adjustments on them? (-1 -2.....and +1 +2 etc)?
    thanks
    VS UTE, HT MONARO REBUILD
    Dec 2010
    IMO i wouldnt bother changing it if there is nothing wrong with it. ive found that unnecessarily changing parts usually causes problems to arise that were not previously there.
    VS Berlina/ KJ Verada
    Sep 2006
    Agreed, if it ain't broke don't fix it!
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    As above, its not really a part that you replace per service intervals etc. If its fine now there's no need to replace it on what's an otherwise stock motor. The plus and minus number are in degees of advanced and retarded cam timing i.e. its adjustable for dialing in an aftermarket camshaft.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    ah ok cheers guys, ive herd that they can stretch on stock standard engines that have not been driven hard at all and oonly have round 100 000k's and have no symptoms of noise etc..
    what about fitting stronger valve springs? or is that only if id go with a cam shaft? im thinking of ripping heads off etc and changing all the gaskets
    also i have a weird scraping sound coming from me engine when i turn at the lights from a stand still, like lights turn green so i go then i hear this noise from the engine, its a weird noise like scrapping noise, its deffinally coming from inside the engine? any ideas?
    VS Stato l67
    Mar 2009
    Melb
    No need to change valve springs unless your aftermarket cam/rocker combo needs it.
    I got my heads pulled off about 2 years ago but only because my manifold gasket was gone so I thought better off getting everything checked out while the supercharger and manifold was off. But if there's nothing wrong I wouldn't do it for the sake of doing it.
  1. Replies: 10
    Last Post: 23-04-2012, 11:59 AM
  2. timing chain tensioner? is it worth it
    By steveabbott in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2010, 11:21 AM
  3. [Ecotec] Double row timing chain worth it?
    By maldotcom2 in forum V6 Development And Modification
    Last Post: 07-02-2010, 07:58 PM
  4. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  5. vn timing chain
    By kacriss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2005, 07:02 PM
